Results 1 to 21 of 21
    Oct 2012
    Getting a Zee derailleur to work with a 11-40 cassette
    I'm having a little trouble getting this setup right. I've got a 1x10 with a 30T oval, zee derailleur, and attempting to mount a Sunrace 11-40 cassette. The chain was a little too long at first, with too much slack on the 11T. Then I took a link out and it was too short for the 40T. Not sure what I can try other than getting a medium cage derailleur. Maybe I need to add a link back and mess with the b screw??
    B A N N E D
    Is the Zee a FR or DH derailleur?
    Is the B-Link/Bracket Axle Unit in a horizontal position?
    Deore XT Frame Compatibility
    RAKC
    Reputation: tigris99's Avatar
    The set up works fine, why do you say too short on the 40t? Or too much slack on the 11t?
    Chain length is big cog on cassette, not through the derailleur, wrapped around chain ring to where it would meet plus 2 full links. Then route through derailleur and connect the chain with the quick link and done.
    There is going to be a little slack when on 11T but I've been riding the set up for 2 years now without issues. I did buy a goat link from wolf tooth to get shifting back to as good as with shimano cassette.
    Sent from my SM-T350 using Tapatalk
    Oct 2012
    I've got the Goat link on there, BUT you were right it wasn't horizontal. So I moved it to a horizontal position, but the little tab that serves as a stop isn't touching anything so it looks like it could rotate down if anything loosened up. Does that tab need to be in contact with the hanger?
    It looked way too slack on the 11T but that was probably because of the horizontal issue. Then it was too short because it couldn't get around the 40T (got maybe halfway on before it was too tight).
    RAKC
    I have seen more than once that people have a goofy hanger on their bike that allows the rd to sit in some stupid positions. The goat link has a pin that rests against the stop.
    I do remember not long ago some discussion about direct mount derailleurs from shimano that requires a goofy hanger. Didn't that that ever materialized though I could be wrong.
    Sent from my XT1565 using Tapatalk
    Reputation: roadracerX's Avatar
    When I installed my Zee short cage and Praxis 11-40 cassette I also dropped 2 teeth on the front chainring on my hardtail. I used the original hanger and only needed to adjust the B screw and it works great with the original chain length. Are you installing this on a HT or as your name applies...a Rumblefish?
    Oct 2012
    It's on a Carbon HT that has a funky hanger that sort of sticks straight down. If the tab were to rest against it, the natural position Of the axle unit is about 8 o'clock.
    My plan is to add back a link to the chain and see if I can use the B-screw to sort it out
    B A N N E D
    Post a photo of the setup.
    Should of posted this thread on here: Drivetrain - shifters, derailleurs, cranks - Mtbr.com
    B A N N E D
    Quote Originally Posted by Rumblefish29er View Post
    The direct mount hanger on the left doesn't use a B-Link/Bracket Axle Unit, the normal derailleur hanger on the right needs a B-Link/Bracket Axle Unit.
    Getting a Zee derailleur to work with a 11-40 cassette-1015989d1442458032-xtr-m980-rear-derailleur-usable-direct-mount-frame-dmlink_b2link.jpg
    Sounds about right on a normal derailleur hanger, some people mount the derailleur at 6 o'clock and find that it won't work properly at that angle.
    The Zee FR has a capacity of 11-36, so it sounds like your pushing it with 11-40. You might be able to get it to work with GoatLink but i'd consult with wolftooth first. You could still end up have issues with chain growth.
    AL
    Oct 2012
    So, I got it to work sort of. After getting the chain length right, and installing the goat link, it came down to the b screw. I had to compromise to get it to work. Just enough to to keep tension on the 11T, and it didn't shift on the large sprockets very well. Adjust the b screw on the largest sprocket, and the chain was too loose on the small sprockets. I was able to ride a fairly technical 4 mile loop near my house, but the shifting really was not great. I think I need to get a RADR cage or a medium/long cage derailleur.
    B A N N E D
    Some photos of the setup might be useful in this thread.
    Oct 2012
    This is with the b screw adjusted to a 5mm gap between the pulley and the 40T
    B A N N E D
    What's it look like on the 40 tooth sprocket.
    Oct 2012
    So here it is once I have put enough tension on the b-screw to get ride of the slack chain at 11T. It shifts up to the larger sprockets pretty well, but shifting down to the smaller ones suffers. I could get by, but it's really not too good.
    I've gotten it to an acceptable, but not as good as stock, point with hyper fine tuning of the limit and b-screws. I think things will wear out quickly like this. I ended up biting the bullet and ordering a RADR cage, which should allow for a more appropriate level of b-tension, and still be able to take up chain slack.
    Could the fact that it's an older chain and a new cassette be part of the issue?
    B A N N E D
    There's more then a 5mm gap between the pulley and the 40T in that last photo.
    Should that goatlink be on that angle or be more horizontal?
    Look at the setup of some Zee rd's with 11-42 cassettes: Wolf or OneUp 42T Cassette Cog with Short Cage Derailleur
    Oct 2012
    Update: the RADR cage with the stock b-link is the way to go. Great shifting.
    I tried the goat link by itself, and couldn't get the tension right.
    I tried the goat link AND the RADR an I couldn't get the b screw right. It was better than just the goat link though.
    Finally, the RADR cage with the stock b-link has performed very very well.
    Edit: I think the goat link would probably work well if using a medium or long cage derailleur for the project.
    Chris Bling
    Reputation: dustyduke22's Avatar
    I ran a 11-40 with a 30 tooth ring with no problems with my Zee. You need the FR model, not the DH. I adjusted the B tension quite a bit to get it to ride right but otherwise it was perfect. Once I bumped to the 42 tooth, I used a RADr cage
    Sent from my SPH-L720T using Tapatalk
    The obsession of wheels fused with the passion of cycling
    Affordable Custom Wheels
    Mar 2012
    Ordered Sunrace 11-40 for my Zee. Will be pairing with new KMC X10.93 chain, 30T RF NW and Saint shifter. My Zee is fitted with some sort of mid cage, however not RADr cage. Looks like either Deore or SLX cage. With XT 11-36 shifts flawlessly so I'm hoping the mid cage will be the ticket for good performance. Hopefully I can get away without Goatlink, they are not the cheapest shipped here and at that point I may as well just pickup 11 speed XT mech and make this a mid upgrade and finish up upgrading to 11 speed when the chain and cassette is dead. Will post once I have a few rides in.
    2014 Giant Trance 27.5 3
    2016 Norco Sasquatch 6.1
    Reputation: thecanoe's Avatar
    I'm following this. I have a 2x10 XT drivetrain on my Tallboy with a 22/32 and 11-36 cassette. I'd like to go to the 11-40. I'm thinking it should shift just fine. At 68 y/o, I'd like a lower bail out gear.
    Santa Cruz Tallboy
    Moonlander
    Mar 2012
    Got a new Sunrace 11-40 mounted with new KMC X10.93 chain. Also changed from 30T Race Face NW to 32T RF NW and while I was there mounted Blackspire Crusher bash guard. My Zee is fitted with some sort of mid cage however, looks like 10 speed Deore one to me. On the stand so far no issues shifting. It may not be 100% as fast or crisp as my XT setup but close enough. It does drop the chain when backpedaling quarter of a turn. I played with spacers to get a bit better chainline, but still no improvement when backpedaling. Ended up leaving one spacer between spider and chainring as with no spacer and short 1x chainring bolts it was quite extreme. This is all on SRAM S1000 GXP 2x10 crankset with 32T RF NW on a '14 Trance.
    Will have to go for a ride for a true test, but looking promising so far.
  1. Will shimano XT cassette M8000 work SRAM X01 derailleur + shifter?
    By egr551 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-20-2015, 07:45 AM
  2. Will a 10 sp. rear derailleur work on a 9 speed cassette?
    By ascarlarkinyar in forum Beginner's Corner
    Last Post: 08-20-2014, 03:18 PM
  3. Can a X9 rear derailleur with a med. sized cage work for 2x0 + 36T cassette setup?
    By fuzzyBuzz in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-18-2014, 06:20 PM
  4. Will a Shimano 9 speed 12-36 cassette work with SRAM short cage rear derailleur?
    By Stonebreaker in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-16-2014, 06:29 AM
  5. sram X9 type 2 rear derailleur with 9 spd cassette, will this work
    By lolaralph in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-03-2013, 12:23 PM
Members who have read this thread: 54
