Results 1 to 7 of 7
    Dec 2010
    Gearing Ratio for 2x9?
    I have already converted one bike to a 1X9 setup. I was wanting to swap out the big ring on my 3x10 for a bashguard but to get more out of the 2 ring setup I was thinking of going 24, 36 on the front. Has anyone tried this ratio? Do they make a 26 tooth granny ring? What are my options for going this route as far as shifting and such?
    T.W.O.
    Reputation: mimi1885's Avatar
    It depends on the BCD and what kind of crank you have. I've seen 24 and 26 granny. I love my 22/36 set up.
    Mountain Man Dan
    Reputation: ProjectDan35's Avatar
    I also run 22-36-bash on my double specific crankset. 36t is nice.
    www.bigrobracing.co.uk
    Reputation: robdeanhove's Avatar
    Dec 2005
    I run 24/36 on my full sus and 26/38 on my hardtail (where I can stand up and mash the climbs bob free). I found TA do chinook chainrings in all BCDs in those sizes. Oh, and my bikes are 29er, so that gearing will be easier on a 26" bike.
    I've found keeping the gap at 12T at the front keeps the shifting great, 14T will make it worse shifting up under power.
    Maromero
    Reputation: doccoraje's Avatar
    I went 2x9 a couple of years ago, first with an Extralite Gara 42-28 which ended being too much for my weak legs and the trails I ride, after that I changed to TA Chinook's 40-26, working OK paired with an 11-34 cassette, now using the same gear ratio, but with Carbon-Ti chainrings.
    www.derbyrims.com
    Reputation: derby's Avatar
    It depends on your speed limits climbing, traversing, and downhill. A 10 to 12 tooth gap is an easy shift and usually appropriate.
    Back when there were only rigid frames I used a 42/26 plus bash. Now much older and slower, I never need more than 22/32/bash off road.
    Edit: that 42/26 was with a 28/12 7-speed cog set.
    Reputation: Nater's Avatar
    24/36 with an 11-34 tooth works well for me on my dual suspension 29er.
  1. ratio/gearing question
    By snowdenn in forum Singlespeed
    Last Post: 08-08-2008, 06:51 PM
  2. 29er SS gearing ratio 32x......?
    By dawgcatching in forum Singlespeed
    Last Post: 07-15-2008, 12:42 AM
  3. Replies: 1
    Last Post: 09-08-2006, 04:55 AM
  4. Gary Fisher Rig 29" Gearing Ratio
    By cbrider1 in forum Singlespeed
    Last Post: 05-15-2006, 05:11 PM
  5. The Age-weenie ratio > rider/bike ratio
    By Chester in forum Weight Weenies
    Last Post: 06-09-2004, 05:23 PM
