Results 1 to 3 of 3
Thread: Gearing
    Gearing
    Please explain gearing pertaining to the rear cassete. I am looking for lowest posible for steep climbing. 12-34, 11-34 What does it all mean?
    Reputation: gmats's Avatar
    Apr 2005
    Quote Originally Posted by bikenut316
    12-34 ==> The smallest cog is a 12 tooth cog. The largest is 34.
    11-34 ==> The smallest cog is a 11 tooth cog. The largest is 34.
    34 is pretty much the largetst rear you're going to find. So if you're looking for lower gearing, you will have to use smaller front chainrings. Depending on which type of cranks you have, you'll be limited on this end to about a 22 or so. If you run 94/58mm compact drive (5 bolt stuff), then it's possible to get 20 tooth grannies and even 29-30 tooth middle rings.
    Hope that helps.
    aloha,
    g
    Quote Originally Posted by gmats
    Hope that helps.
    aloha,
    g
    Thanks it does.
