Results 1 to 7 of 7
    need more bikes!
    Reputation: BOhNSAI!!!'s Avatar
    Dec 2005
    Gear Indicator Died in SRAM Rockets
    My gear indicators died in my SRAM rockets and I can't seem to fix it. Has this happened to anyone else? Is there a trick to fixing it? My guess is they couldn't handle the abuse at Ray's
    "someone set up us the bomb" No puedo sentirme las piernas
    04 Stinky Primo for sale. Please buy it so I can buy more bikes, Please!
    No, that's not phonetic
    Reputation: tscheezy's Avatar
    What have you done to try to "fix it"? Did you take the shifter apart? That's how I fix them.
    My video techniques can be found in this thread.
    need more bikes!
    Dec 2005
    yeah, i took the cover off and made sure the little teeth weren't broke. After I put it back together it works but as soon as I put in the bolts it quits working.
    Make sure the teeth are either straight or bent down a little. It sounds like they are jumping up above the cog that is supposed to push and pull on the indicator. It's not like the cog attached to the shifter is not turning, it's that the indicator is not getting moved along with it.
    need more bikes!
    Dec 2005
    yeah, they work fine otherwise. I'm sure that with more fiddling I can get them to line up.
    Meh.
    Reputation: XSL_WiLL's Avatar
    Your legs should be able to tell you what gear you're in anyways.
    need more bikes!
    Dec 2005
    They alway lie and tell me I'm in the "too hard" gear
