Results 1 to 2 of 2
    fsa omega triple crankset with 135mm rear spacing
    My 2010 kona sutra came with that setup(megaexo). the right crank arm is 2.5mm closer to the downtube than the left one.is the chainline right or should i add one 2.5mm spacer to the driveside? omega triple is road crank(bottom bracket is 68mm) so was presumed to be used with 130mm rear, but what about 135mm rear?
    need more bikes...
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by enio
    The chainline is probably better as it is.
    mtbtires.com
