Results 1 to 5 of 5
Thread: FSA BB help
    Big Wheel Homer !!
    Reputation: cruzthepug's Avatar
    FSA BB help
    I need help. I installed a new FSA pro platinum bb last night. Followed the instructions, and the left cup is still 3-4 threads from being flush with the shell. Is this normal? I also took it down to my LBS and had them check it, and thats as far as it will screw in. I won't be able to call FSA until later, and was hoping someone here knew the answer.
    Thanks,
    Steve
    My only thought is they sent you a 73mm shell BB and you have a 68mm shell BB on your frame. That would leave 5mm exposed, and the couple of FSA's I've installed didn't sit quite flush anyway, they would leave the shoulder exposed. So 3-4 threads would be about right if you got a 5mm too long of a shell BB.
    Big Wheel Homer !!
    I've got a 73mm shell and ordered a 73mm bb. I have let every shop in town look at it today, and have come to the conclusion that it's fine, everythings tight, just ride it.
    Thanks,
    Steve
    Dude!
    Reputation: Mo-Tay's Avatar
    I have the same issue....Plat Pro that sticks out a bit. It is fine.
    Reputation: Atomik Carbon's Avatar
    Here's what you do...
    Put a lock ring on it to protect the threads and give it a finished look.
  1. FSA X Drive BB
    By shiggy in forum Singlespeed
    Last Post: 02-24-2005, 09:46 AM
  2. FSA outboard bearing ISIS BB
    By jokermtb in forum Turner
    Last Post: 10-23-2004, 08:22 AM
  3. ISIS debates have me confused?
    By keen in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-10-2004, 09:32 AM
  4. Lightweight, durable ISIS BB?
    By 1speed_Mike in forum Weight Weenies
    Last Post: 09-01-2004, 01:07 PM
  5. FSA Afterburner BB for 2004 Stumpy FSR
    By riverrat in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-29-2004, 11:23 PM
