Results 1 to 5 of 5
    front sram shifter, click 3 times? or more?
    I just installed a pair of sram rocket shifters. Is the front shifter suppose to only click 3 times or more? It makes sense to just move from 1 to 2 to 3 to move from the largest crank ratio to the smallest but mine clicks 8 times to move through all 3 numbers.. is mine faulty?
    thanks
    Kelvin
    BLS439
    Reputation: BLS439's Avatar
    Quote Originally Posted by Kelvin
    thanks
    Kelvin
    This is probably not the best answer but from what I recall, it shifts more than 3 times for the front shifter. I am not sure if it shifts 8 times but definitely more than 3. It should have several clicks between gears that do move the front derailleur a small distance kind of like micro adjustments to stop rubbing, etc.
    It has been over a year since I had rockets on my blur. I actually really liked those shifters but wore them out in a few seasons.
    --BLS439
    rr
    rr is offline
    I don't do PC
    Reputation: rr's Avatar
    thanks
    Kelvin
    No worries, it's supposed to do that. It's actually a benefit, it allows for micro adj's so there is no chain rub on the der. like with shitmano shifters.
    meh....
    Reputation: Monte's Avatar
    thanks
    Kelvin
    Normal. After a while you'll count the clicks between shifts and won't have to look at the chainwheels or indicator, if you do at all anyway.
    Monte
    i see
    Thanks lots guys.....
  1. blast from the past, cut/paste from archived MTB DOC posts
    By ashwinearl in forum XC Racing and Training
    Last Post: 02-09-2005, 09:47 AM
  2. defective SRAM X.9 shifter "cable-change caps" ?
    By PiroChu in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-15-2004, 09:29 AM
  3. Trim front derailleur with twist shifter? Explain please.
    By Northern Virginia Rider in forum SRAM
    Last Post: 05-24-2004, 12:27 PM
