Results 1 to 1 of 1
    Drink...sleep
    Reputation: Boozzz's Avatar
    Aug 2005
    Bonking ... not feelin' well Front mech plate and chain worn by rub, help!
    Hi guys,
    On my Cannondale Prophet 700 SL with FSA Mega Exo crank, this is what happens when I run the front derailleur according to Cannondale's FD setup guide here: the chain slightly rubbing the e-type FD plate while in lowest gear up front, thus wearing out the chain as well as scratching the FD plate (the bigger damage slightly higher up btw. is from a case of chainsuck). Has anyone else ever experienced something like this or knows what could be the problem? Should I switch the spacers on the BB around, although this is not according to Cannondale specs? The LBS is no use, as they know absolutely nothing. Thanks!
