Results 1 to 5 of 5
    New question here. Front derailleur questions
    I recently purchased an '04 Trek 4100. I havent rode in years.Well Im looking to upgrade the front drailleur from the stock Shimano top-swing C051 to a Shimano Deore LX unit. I guess my is which one should I use another top-swing unit or a link-type. Not sure I know what the advantages or dis-advantages are to either. Im also considering a rear drive train upgrade from 7 speed to 9 speed soon.
    Thanks,
    Sinkhole
    '04 TREK 4100
    DRIVETRAIN:
    SHIFTERS: Shimano EF29
    FRONT DERAILLEUR: Shimano C051
    REAR DERAILLEUR: Shimano Acera
    CRANKSET: SR XCC100 48/38/28
    CASSETTE: Shimano HG40 14-34, 7 speed
    PEDALS: Nylon platform
    Quote Originally Posted by Sinkhole3000
    Thanks,
    Sinkhole
    '04 TREK 4100
    DRIVETRAIN:
    Looking at that parts list, it is pretty much bottom of line. If you don't plan on riding much, or just occasionally, all parts you have are fine. If you want to upgrade to a 9 speed system, it will cost plenty. You have to make sure bike is worth it at that point. Since it started life as a 7 speed, I would say probably not. Changing out the front derailleur, unless there is a problem with it, will make absolutely no difference. Save your money. I would ride the wheels off it for awhile and see if you want to get back into it. Then it would be time to upgrade bike frame, etc.
    On MTBR hiatus :(
    Front derailleurs are one place you're ok to skimp: they're brute force components and the lighter weight and/or higher priced ones don't necessarily tend to shift any better or last any longer. I would honestly be happy with a Deore level front mech, regardless of what the rest of the drivetrain is comprised of.
    If you have top swing currently, you may not be stuck with it as long as you have clearance on your seat tube (i.e. no water bottle bosses or frame gussets). I prefer bottom swing (high clamp) over top swing (low clamp) units because of their beefier construction. There are a lot more pivots, and a lot of stamped metal parts on a top swing derailleur that can lead to bent cages and premature wear. Bottom swing, on the other hand, uses two nicely forged arms and four straight-through pivots and, for me at least, seem to last forever.
    Hi Nate,
    I think you have the two types reversed in your above post. Bottom swing derailleurs have less pivots but top swing derailleurs are more compact and take up less height on the seat tube.
    On MTBR hiatus :(
    Quote Originally Posted by CharT
    Hi Nate,
    Oops, yeah, I said that wrong. I'll edit my post. Thanks.
  1. Morphine front derailluer?
    By teamdicky in forum Downhill - Freeride
    Last Post: 08-04-2004, 04:07 AM
  2. Front Shock Questions
    By dnale in forum Shocks and Suspension
    Last Post: 04-16-2004, 12:31 PM
  3. Front derailleur questions: Swing type and model suggestions please...
    By DCepp in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-10-2004, 08:16 AM
  4. Front Derailleur questions??? My new frame will
    By Scott479 in forum Weight Weenies
    Last Post: 02-06-2004, 09:52 PM
  5. Front Derailleur questions??? My new frame
    By Scott479 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-06-2004, 10:14 AM
