    try driving your car less
    Reputation: jh_on_the_cape's Avatar
    New question here. front derailleur that doesnt need a cable stop?
    Long story short: I have a frame with a missing front der. cable stop on the seat tube. Are there are any decent front der. that can run cable housing all the way to the mech? I have only found some on very old low end road bikes.
    I know I know I should just get the cable stop brazed on there... it will happen, but I dread dropping off my frame when riding season is about to go full swing...
    Only boring people get bored.
    Reputation: shiggy's Avatar
    Dec 1998
    Sure it is not setup for a bottom pull derailleur?
    Problem Solvers makes a clamp on stop.
    mtbtires.com
    Quote Originally Posted by shiggy
    Oh I am sure. It's a custom steel frame and the builder noted to me immediately that he spaced that cable stop and is willing to correct it for me, free of charge.
    I will try to find that product you mention.
    Mantis, Paramount, Campy
    Reputation: Shayne's Avatar
    In A Pinch...
    You can run the housing all the way to any f derailleur. Replace the cable bolt on the f derailleur with a threaded cable stop. Then run the cable through this and use use your BB to clamp the end of the cable.
    Running the housing all the way to the f derailleur was fairly popular in the late 80's. These frames would have a bolt down near the BB shell to secure the end of the cable.
