Results 1 to 3 of 3
    Oct 2007
    front derailleur adjustment issue
    I was trying to get my bike adjusted properly becuase it wont shift from the middle chainring into the smallest. I removed all tension from the cable and tried to adjust the low limit screw but the derailleur doesnt seem to move far enough to move the chain over. If i move it over manually it rubs really bad. any suggestions on how to fix this.
    Also the cable is pretty frayed so im going to replace it. any brand better than the next?
    Start with a really good cleaning check for small pieces of rock and dirt that may affect the travel range.
    Oct 2007
    good call. ive been hitting up a lot of limestone trails while i await the spring thaw to finish. Ill be sure to do that tonight.
  1. Front derailleur adjustment
    By dhelm72 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-30-2013, 08:31 AM
  2. Front derailleur adjustment Q
    By beanbag in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-02-2012, 08:51 PM
  3. Front derailleur adjustment problems.
    By naiku in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-26-2012, 10:22 AM
  4. X7 Front Derailleur Issue
    By KThaxton in forum Specialized
    Last Post: 03-30-2012, 03:42 AM
  5. Sram XX front Derailleur adjustment problems on Ellsworth Truth
    By karisia_safaris in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-23-2011, 08:50 AM
