    Mar 2013
    Front derailleur for a 2004 Specialized FSR XC XT M770 does not fit. Suggestions?
    I had bought a used group set that included an XT M770 front derailleur that from the description appeared to fit my needs (34.9mm, top pull). However, while having my LBS try to install it, it does not appear to fit. The cable mount seems to be too low and will be in the way of the chainstay pivot at the bottom bracket.
    The original FD that came with the bike was a an M510 Deore, but I'm looking for something nicer to match with the rest of the m770 set that seems to have gone on without any problems.
    The LSB tried a new current model Deore and it had the same problem as the XT though to a slightly lesser degree.
    Are their any suggestions as to what newer FD might fit?
    Reputation: Aresab's Avatar
    It sounds like you need a bottom swing derailleur and a top swing came in the kit you bought? If I recall, the M770 is the top swing (low clamp) and the M771 us the bottom swing (high clamp).
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    Quote Originally Posted by RSabarese View Post
    with out pictures to see the actual issue,.. I'd have to agree with RSabarese
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
    Mar 2013
    Thanks Rsabarese, I think that is the case also. The Specialized product page only states the diameter and pull type but not the swing.
    Thanks for the help.
  1. Sram-Specialized 29er specific front derailleur
    By Davidcopperfield in forum 29er Bikes
    Last Post: 12-25-2013, 06:57 PM
  2. 08 ENDURO front Derailleur suggestions please!
    By HODGY in forum Specialized
    Last Post: 06-28-2012, 09:57 PM
  3. Suggestions for front derailleur replacement
    By craiger951 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-29-2011, 09:47 AM
  4. trigger shifter, which one, front dérailleur suggestions
    By red93crxhatch in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-13-2011, 01:10 PM
  5. Please help I need a new front derailleur any suggestions.
    By thechainring in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-17-2011, 07:18 AM
