Thread: Fourth Hand
    May 2005
    Fourth Hand
    Is a Fourth Hand Tool needed to adjust/setup a front derailleur?
    If anyone knows of a website that has specific instructions for front derailluer installation would you please post it. Thx
    Thx for your help
    Curtlo Hardtail(liatdraH)
    Reputation: liatdraH's Avatar
    Nope
    A fourth hand is particularly useful for adjusting cantilever brakes. Park Tool is an excellent resource for repair and adjustment instruction. http://www.parktool.com/repair_help/...railleur.shtml
    Rule books are paper they will not cushion a sudden meeting of stone and metal.
    Crazy C
    no 4th hand tricks
    Along with the always helpful park site, if you don't have a 4th hand tool there are a couple of other ways to get more cable tension for the f. der.
    What I usually do is to give the lower limit screw about a quarter turn or so in and then attach the cable. After attaching the cable, let the screw back out and the tension should be just about right. The other method is to use the shifter's barrel adjuster...screw it in all the way, attach the cable and back the barrel out a couple of turns to get the tension you need. Good luck.
    May 2005
    Thanx Crazy! ....... I will give it a try.....
  1. fourth hand tool
    By special k in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-13-2005, 06:24 AM
  2. Left Hand Fire - OHV area
    By ignazjr in forum Colorado - Front Range
    Last Post: 09-17-2004, 10:16 PM
  3. Replies: 2
    Last Post: 07-14-2004, 05:26 PM
