    Jun 2005
    Fixed XX rear derailleur
    My XX rear derailleur developed some slop between the p knuckle and outer cage due to wear in the cage spindle and retainer pin. To fix it I ground off the shoulder on the spindle, threaded the spindle to accept a 6mm nut(with nylon lock), rounded the nut to make it fit inside the knuckle with no resistance or slop, positioned the nut so there is no slop between the knuckle and cage and locktited it in place. I had to make flats on the spindle to cut the threads so I wasn't putting force on the carbon cage(not on the part that interfaces with the knuckle, close to the trough the retaining pin sets in). Will report how it works on the trail over time. Hope it saves a $$$ derailleur, nothing to lose....
    Hopefully pics show repair well enough to make it clear. You can see the wear on the pin, sorry no pics of the shoulder before i ground it off.
    Attached Thumbnails Attached Thumbnails Fixed XX rear derailleur-img_5789.jpg
    2008 Kona Kula 2-9 SS 2010 SWorks Epic
    Riding trails you maintain is more fun.
    I <3 dirt
    Reputation: Ilikemtb999's Avatar
    Oct 2010
    I would have went the warranty route.....
    Jun 2005
    Yes, warranty is always preferable, but I am not the original owner and it is almost 4 years old. Then repair is doing nicely and has improved the derailleur performance so I no longer chainsuck or misshift, kinda like new!
    Jun 2012
    Help
    Quote Originally Posted by thinman View Post
    Sorry that this is so long from when you originally posted. I see you were able to remove the cage from the derailleur body. I'm having trouble doing so. How were you able to remove it?
  1. 575 Carbon Rear Tri. FIXED!!!
    By TRAIL CRANKER in forum Yeti
    Last Post: 10-23-2012, 09:15 AM
  2. Paul WHUB as rear fixed hub?
    By cheepnis in forum Wheels and Tires
    Last Post: 05-07-2012, 07:59 AM
  3. Fixed the derailleur last night on my old bike
    By htjunkie in forum Beginner's Corner
    Last Post: 10-13-2011, 05:48 AM
  4. broken derailleur....is now fixed
    By Cantil3v3r in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-24-2011, 08:15 AM
  5. Rear Brake Rub fixed Fly Ti 29ers
    By iowacutter in forum Motobecane
    Last Post: 04-13-2011, 11:24 AM
