Results 1 to 11 of 11
    Reputation: KevinGT's Avatar
    Dec 2012
    First broken chain in 20+ years
    When I had my new bike built in March, my LBS nearly insisted they use a quick link on my shimano 10 sp chain. I told them I'd been riding shimano chains since 1988 and preferred pins
    They talked me into a quick link. Four months later, I broke my first chain -- the quick link, specifically
    I'm going back to shimano pins but I've heard they break often as well. Which is the lesser of two evils, shimano pins or quick links?
    Reputation: donthucktoflat's Avatar
    Apr 2013
    Re: First broken chain in 20+ years
    Ive never had a sram quicklink fail, kmc or wipperman links get good raps also but the new 10sp sram ones are most definitely impossible to remove without the tool
    meow meow
    Reputation: b-kul's Avatar
    it was probably installed wrong.
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    SRAM and KMC....done.
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    Reputation: J.B. Weld's Avatar
    Shimano connecting pins are good, I connect all my own that way and have never had a failure. Also many years of trouble free use of them at shops confirms my personal experiences. This was pre-10 speed days but I'd guess the new ones work just as well.
    I think a properly installed Sram or KMC link is fine too.
    I like pie.
    Reputation: Mr5150's Avatar
    Dec 2011
    Quote Originally Posted by KevinGT View Post
    Your title says it all.
    I've run Shimano chains since 1992 and never had a failure.
    I've broken chains, but never at the quick link or special pin. I prefer quick links since I regularly remove my chains to clean them.
    As to what happened, some of the 10 speed quick links are directional, I'm not sure of the KMC ones but I know the SRAM ones are. There's an arrow on them that points in the direction of chain rotation, if you put them in the wrong way it may lead to an early failure.
    Plays with tools
    Reputation: customfab's Avatar
    I've seen a bunch of broken quick links at races, I've never seen a broken shimano install pin. I do not like quick links, I'll use them with a chain if that's what the manufacturer shipped them with though. I've never understood why some people are so hung up on taking the chain off in the first place, clean the damn thing on the bike!
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    have broken/seen broken multiple dozens of shimano chains. almost always at the install pin. Will say it's probably 99% do to improper install in the first place.
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
    I've broke one SRAM powerlink. Only chain I've ever broke was also SRAM. Back to shimano and kmc chains and no issues so far
    Sent from my HTC EVO LTE
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Quote Originally Posted by ricky916 View Post
    Same here exactly. I switched to kmc and zero issues since.
  1. Keep using a broken chain?
    By GTscoob in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-03-2012, 10:10 AM
  2. Broken chain!
    By DigitalDJ in forum Beginner's Corner
    Last Post: 02-07-2012, 03:15 AM
  3. HELP!!! Broken Chain!!!
    By chewie_52 in forum General Discussion
    Last Post: 01-03-2012, 09:11 PM
  4. HELP! Broken Chain
    By chewie_52 in forum Specialized
    Last Post: 01-03-2012, 07:30 AM
  5. Broken chain
    By Johnny? in forum Beginner's Corner
    Last Post: 04-06-2011, 01:14 PM
