Results 1 to 2 of 2
    Evolve XC Crank Removal???/
    How do i remove the cranks on my Race Face Evolve XC setup? Is it necessary to remove the chain? The cranks barely spin. I have no idea what the problem could be!!!!
    Reputation: johndcurtis's Avatar
    No, you won't have to remove the chain, just drop it off of the chainrings before you try to remove the cranks. It sounds like there is a problem with your Bottom Bracket, assuming the cranks used to work well, You probably got some water in there and will need to look at getting a new bottom bracket for ISIS or square taper style, or new bearnings for the new-style cranks with the outboard bearings.
    Check out what Park has to say: http://www.parktool.com/repair/byreg...ageField2.y=14
