Results 1 to 2 of 2
    locked - time out
    egg beater sl end plug/cap
    Just received my new egg beater sl pedals today. Right out of the box they have alot of
    spindle play/slop. I thought I would unscrew the eng plug and give nut a little snug. No
    such luck. The end plugs are so tight I'm destroying them. On the box it says aluminum,
    black anodized end plugs. These are plastic. Suggestions on removing them? I think
    the only way will be to destroy them. Them what to do for end plugs?
    locked - time out
    Solution
    If anyone has this problem here's what I did. Sprayed a little triflow on the end plug and
    let it seep into the threads. Took a hair dryer and heated it a little. Let it cool for a few
    minutes and presto they broke free. Upon removing the end plug the threads were coated
    with a varnish type substance that seized them to the pedals. Cleaned the threads and
    greased and reinstalled. The plugs look a little chewed up but I'm hoping Crank Brothers
    has another set laying around.
