Results 1 to 5 of 5
    E13 Chainring + BBG bashguard = Which bolts to use?
    I'm doing a 1x9 conversion (as well). Which chain ring bolts to use(Length/size)? Can I use my stock LX bolts or do I have to buy new ones.
    Dirt Deviant
    Reputation: savagemann's Avatar
    You should be able to use your stock bolts.....pretty sure. As long as they are for a double.
    Do you have one of the BBG lite bashguards?
    Look, whatever happens, don't fight the mountain.
    Not the Lite one. The one with drilled holes.
    Dirt Deviant
    The stock hardware SHOULD work fine.
    meow meow
    Reputation: b-kul's Avatar
    stock is fine. a bbg bash is about the thickness of the ring it is replacing.
