Results 1 to 1 of 1
    E-type derailleur rubs 34 tooth middle. What are my options?
    I want to run a 34 tooth middle chainring with my E-type front derailleur but the inner cage plate rubs the middle ring when riding in the big ring. This can't be adjusted out. The E-type I'm using (XTR FD-960E) specifies 12 tooth min drop from big to middle (meaning a 32 tooth max with a 44 big), so I suppose this is what I get. Do I have to grind away the inner cage plate to provide clearance or is there something else I should try first?
  1. Front derailleur won't behave
    By SpinWheelz in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-10-2004, 03:23 PM
  2. wanted: 34 tooth 110mm bc
    By scottms33 in forum Singlespeed
    Last Post: 04-04-2004, 06:39 PM
  3. is 34 tooth chainring better than 32?
    By head in forum Singlespeed
    Last Post: 03-13-2004, 12:14 AM
