Results 1 to 5 of 5
    HowtoOverthrowtheSystem
    Dura-Ace / XT parts mix
    I have a couple questions...
    I'm thinking about building up a Surly Long Haul Trucker for loaded toruing. I am thinking of stripping some parts from my old hardatil MTB. I have an XT crank 22/32/44 with a 11-34 cassette and XT front and rear derailleurs. I am wondering if I can use Dura-Ace downtube shifters with the XT derailleurs.
    Do you think I will have clearance problems with 175mm cranks? I plan on using the 56cm LHT with 3.1"/78mm BB Drop.
    I have a set of 32-hole Chris King hubs built up with Bontrager Mustangs and 14/15 spokes. Should I get a stronger wheelset or build this up with stronger spokes and brass nips?
    I'm trying to do this on the cheap. I'll probably be hauling 50-60 lbs of gear distributed over front and rear racks.
    All 26.5" all the time!
    Reputation: Zanetti's Avatar
    Quote Originally Posted by daveIT
    8 speed - no
    9 speed - yes
    10 speed - no
    Edit: 10 speed DA shifters will work with an XT RD if you're using a 10 speed cassette.
    9-spd Dura-Ace downtube shifters or the XT components? My XT stuff is 9 spd.
    Might have found the answer:
    http://www.bikeforums.net/archive/in...p/t-82290.html
    "There *is* only one model of 9-speed bar-end: Dura-ace (SL-BS77). They work in all Shimano 9-speed setups with all Shimano indexed rear derailers *except* pre-9-speed Dura-ace. For the pre-9-speed Dura-ace (RD-7400), they actually shift 8-speed spacing. Before 9-speed, Dura-ace shifters only worked with Dura-ace rear derailers and that is probably the origin of the statement."
    Sound right?
    9 speed parts will work together, down tube or bar end.
  1. Dura Ace / XTR compatibility
    By pinepig in forum 29er Bikes
    Last Post: 10-18-2006, 06:30 PM
  2. Dura Ace + narrow cog?
    By the Inbred in forum Singlespeed
    Last Post: 01-06-2005, 04:28 PM
  3. Dura-Ace BB instead of 04' XTR BB
    By daggert in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-20-2004, 12:03 PM
  4. Dura Ace set up help
    By rjpstoked in forum Weight Weenies
    Last Post: 02-24-2004, 06:00 AM
  5. SRAM 2x9 Vs Dura-Ace 3X9
    By CulBaire in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-14-2004, 12:02 AM
