Results 1 to 11 of 11
    Barney 4 Life
    Reputation: MileHighMark's Avatar
    Dumonde Tech application?
    I cleaned the chain with an ultrasonic cleaner, and then rinsed with 99% isopropyl. Lubed each link with two (2) drops of "original" Dumonde, and wiped off what little excess there was. That's it, right?
    GRAVELBIKE.COM - ride everything
    That's it until the next time I suppose....that is way more effort than I've ever put into cleaning and lubing a chain. Did you already have an ultrasonic device?
    suum quique
    Reputation: Joules's Avatar
    pretty much. the thorough cleaning is really only needed for initial application, next time you lube just wipe off the surface and reapply the dumonde.
    Barney 4 Life
    Quote Originally Posted by Bikinfoolferlife
    Normally I'd just wipe the chain off with a rag, and lube it, but from what I was able to glean off the 'net, Dumonde works best with a really clean chain.
    The ultrasonic cleaner was purchased for my business, but it's great for cleaning chains and cassettes. It's a fairly small unit (now there's a straight line!), so an 11-34t cassette doesn't get fully submerged. Chains, however, come out looking better than new.
    If I were going to switch lubes during the chain's life, I'd do a thorough cleaning too but since a chain's going to be replaced relatively soon I'd just wait until the next chain change, but that's me but then I don't have an ultrasonic cleaner to help out. Let us know if the Dumonde lube is better than sex.
    suum quique
    I just do about 30 seconds with a Finish Line device and some Simple green. Wipe dry. Let it sit a bit. Backpedal while squirting some finishline "red".
    I used to do each link, but I haven't noticed a difference except for the extra lube that I wipe off at the end.
    Overkill IMO.
    Reputation: wyrm's Avatar
    Dumonde is some of the best stuff. I have switched the whole crew over to this.
    Bikeless Rider
    Barney 4 Life
    I rode for an hour today, and the chain didn't pick up much dirt (see crappy phone pic below). With Pro-Link, I'd have to lube before the next ride, but I'm pretty sure that's not necessary with Dumonde. I'm going to see how many hours of ride time I can log before having to (A) re-apply more Dumonde, and/or (B) wipe the chain down.
    Wow....ultrasonic cleaner, two drops per link....damn. I just squirt some off and wipe off the excess. Works for me.
    I bought a small ultrasonic cleaner on sale at Harbor Freight for $25 just for cleaning chain and other small parts. Works great! I do cycle it several times then I cycle it a few more times using water. I also rinse chain in some denatured alcohol to remove water.
    The mechanic that assembled my bike showed me his chain oiling technique using white lightning; after rotating chain several times while he adds lube, he then lights the chain using a pocket lighter which burns away the excess solvent leaving the lube residue on chain. He does wipe off the excess residue.
    I have been using this technique on the original chain that now has 1800+ miles on it with less than an 1/8 stretch. I do use a good quality chain, the shimano 7701.
    Barney 4 Life
    Rode for another 45 minutes* tonight, and the chain was just starting to make some noise. It wasn't the evil "chirp" of a totally dry chain, but rather the "sloppy" sound of an under-lubed chain.
    One thing I noticed while racking the bike was how little dirt was on the chain. There was a coating of dust, but not the greasy stuff you'd see on a wet-lubed chain. I ran my finger over the rollers, and there was only a powdery residue left behind. I back-pedaled the chain through a rag, and it came surprisingly clean. I could probably eek out another 30 minutes of ride time, but I'm going to give the chain a one-drop-per-link lube and see how long the reapplication lasts. Thus far, it's out-lasted Pro-Link Gold, so I'm pleased.
    *All riding is off-road, and is actual rolling time.
Hot Deals
Contests
Latest Mountain Bike Articles
