Results 1 to 6 of 6
    Professional Bad Ass
    Feb 2007
    Dues XC Triple Double conversion
    I decided to try Rotor's 38/25 chainring combo on my RaceFace Dues XC triple crank. Unfortunately, I found out that the little ledge the chainring sits on has a slightly bigger diameter for the middle ring than the outer ring, which means the 38t ring can't be mounted to the middle position as i was hoping. Is this fitment standard? Will the 38t fit an XT triple crank in the middle position? What about the newer Turbine 104/64 double crank? Will raceface 104/64 double chainrings fit the Dues?
    Mar 2011
    I've had a similar issue with Shimano 104BCD chainrings before when they changed the shoulder height - I dremeled about 2mm off the chain ring tabs and it fit fine
    Feb 2007
    Did you still have some shoulder left? If I dremel the shoulder on the Dues it will be mostly gone. The small ring has no shoulder, but also uses steel chainring bolts, vs alloy for the big/middle. Is it ok to mount the middle with no shoulder if you're running steel bolts?
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by dthomp325 View Post
    Yes, the shoulder does little to support the rings.
    mtbtires.com
    Agreed, I have the Deus with Blackspire 38x26 rings and the 38 doesn't sit on the shoulders. No issues.
    Feb 2007
    Well, after going through the trouble of filing off the shoulder, I realized the Rotor inner ring doesn't clear the BB shell I suppose I could try a 3 ring setup and use a non-Rotor ring for the inner ring, but their 33 tooth/44 tooth middle/outer combination is too big for me. Guess I'm going to have to give up on rotor rings. Damn, they seem pretty cool.
  1. MTB triple vs road double
    By Erik_A in forum Cyclocross
    Last Post: 07-08-2012, 09:46 AM
  2. slx triple to double
    By digglesworth in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-31-2011, 07:13 PM
  3. Triple to Double
    By CS2 in forum Vintage, Retro, Classic
    Last Post: 05-02-2011, 01:28 PM
  4. How to convert a triple to a double???
    By mojobeer in forum All Mountain
    Last Post: 04-16-2011, 12:28 PM
  5. SLX Crankset-Double or Triple?
    By angelo in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-11-2011, 06:40 PM
