Results 1 to 6 of 6
    super absorbent
    Reputation: ChipAllen's Avatar
    Mar 2005
    DT Swiss Onyx Disc hub rebuild?
    If I grab the outer edges of the large cassette, I get a little side to side wiggle with my rear hub. The cassette itself is not loose and is tight on the hub so I'm guessing the bearings need to be repacked and/or replaced. Is it possible to have this thing serviced or is it a sealed system? I've never broken down a hub before so I'm very cautious about tearing it apart. If it can be done, I'll likely take it to my LBS.
    The more complicated it is, the more that can go wrong.
    Team Blindspot
    Reputation: S-Works's Avatar
    Quote Originally Posted by ChipAllen
    Is it the freehub body moving? Or is the cassette wiggling on the freehub? Some cssettes don't fit tight. I've shimmed them tight in the past by sliding slices cut from an aluminum soda can (or beer can if you prefer) in between the cassette and freehub body. Try looking at that first before you get into tearing it apart.
    Good Luck
    Astigmatic Visionary
    Axle Nut?
    Sounds to me like the axle nut is loose. Take off the wheel. Check which side the offending nut is on. Tighten the nut with you fingers or a spanner/wrench. Do not overtighten! Check the wheel spins is okay. Put the wheel back in the bike.
    The bearings should be okay, they are sealed bearings. There are rebuilding instructions on the DT Swiss website (www.dtswiss.com).
    super absorbent
    Mar 2005
    Thanks for both replies. I'll look at things more closely this evening.
    Tracking up the place
    Reputation: Haroow's Avatar
    I had the same issue, doesn't matter if Sram Or Shimano cassette. It's play, I remedied it by slippping some teflon tape over the hub and splines and then working the cassette down, and wa la it worked... Hope it helps.
    "Home of the Bearlodge Mtn Classic"
    The only hill is the one you make of it....
    super absorbent
    Mar 2005
    It was definitely play between the cassette and hub. I hadn't read the tip about the teflon tape yet so I just placed the soda can strips in a couple of key places and the problem is solved. Thanks guys!
    P.S. The soda strips were a little bit of a pain so I'll try the teflon next time I remove my cassette. I'm assuming you wrapped it completely around the freehub body? How many layers? What's the longevity like with the tape - does it tend to break down or loosen significantly after a while?
  1. XT disc hubs vs. DT Swiss onyx disc
    By nihilan in forum Wheels and Tires
    Last Post: 08-17-2005, 10:57 PM
  2. DT Swiss ONYX hub - noisy bearing
    By StumpjumperUK in forum Wheels and Tires
    Last Post: 03-27-2005, 02:27 PM
  3. DT SWISS ONYX Disc or XT Centre Lock Hubs?
    By ryan123 in forum Passion
    Last Post: 03-19-2005, 04:48 AM
  4. Broke my Hugi 240 disc hub! Help pls!
    By 9W6VX in forum Wheels and Tires
    Last Post: 02-19-2005, 11:08 AM
  5. DT Swiss 240S Disc rear hub durability
    By riverrat in forum Wheels and Tires
    Last Post: 09-28-2004, 03:12 PM
