Results 1 to 5 of 5
    Dec 2005
    Dropping or increasing 1x11 Sram chainring by 2 teeth...no adjustments needed?
    I have a stock 32T 1x11 on front. I have both a 30T and also a 34T Eagle chainring set sitting here.
    1. Is the rear mech okay to use either without any adjustments?
    2. I'm fairly sure the Eagle xx1 chainrings are backwards compatible with 1x11 stuff, right?
    Reputation: J.B. Weld's Avatar
    Quote Originally Posted by curtlo-dork View Post
    Maybe. For sure it will work with the 30t but if the chain is sized on the tight side with the 32t it may not be ideal on the 34.
    Pretty sure everything is backward compatible too.
    I brake for stinkbugs
    Reputation: ColinL's Avatar
    Feb 2012
    The eagle chainring actually has a weird tooth profile that is optimized for the eagle chain. But if you use both of those with an 11 speed cassette you're OK.
    Sent from my XT1635-01 using Tapatalk
    Dec 2005
    So I can't use an eagle chainring with 11-speed X01 everything else?
    On a 2nd note, I went to install a new chain today, and cut it one link short! doh! I measured twice too, still cut it wrong.
    So now I'm thinking of keeping it, and putting it on when I drop down from 32T to my 30T ring. One link, for 2 teeth, shouldn't be an issue right?
    Reputation: Nutball's Avatar
    Eagle chainring works great with an 11 speed drivetrain. I've used both 11s rings and an eagle ring on my 11s bike and can't tell the difference.
    Sent from my Moto G (5) Plus using Tapatalk
  1. SRAM NX 1x11 dropping off top ring
    By Josh-L in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-25-2018, 02:01 PM
  2. SRAM GX 1x11 chain length and setup questions, sram has no definate on 1x11
    By bertrenolds in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-25-2017, 03:32 PM
  3. difference in performance of XT cassesste 1x11 40 and 42 teeth?
    By Picard in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-15-2016, 04:50 PM
  4. X01 1x11 dropping chains
    By hobo1337 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-01-2016, 06:15 PM
  5. Increasing psi vs increasing compression damping.....difference?
    By beachbum1 in forum Shocks and Suspension
    Last Post: 11-15-2014, 07:53 PM
Members who have read this thread: 45
