Results 1 to 2 of 2
    Jun 2013
    Idea! double chainring options
    What are the double chainring options I have? Granny & big ring? Middle & big ring? I have the RaceFace Atlas crank (second generation) & an 8 speed cassette. Their site says: RING CONFIGURATION: 24,36 & Bash SR & Bash SR Ring.
    I bought the RaceFace Team chainrings 44, 32, 22 T. According to their compatibility chart, they do fit.
    Thank you
    Bicyclochondriac.
    Your options are to use the small/middle, or middle/big positions. Also, shifting between rings more than 14t different can be problematic.
    In practice, the small/middle works best from a chain-line standpoint, because the middle ring lines up a bit outboard of the middle of the cassette.
    Also, losing the big ring lets you run a bashgaurd in that position.
    People have been converting 3x crank to 2x using the small and middle positions for decades.
    If I were you, I would try running the 22t and 32t rings you have, and if you find you need higher gearing, you can swap the 32t for a 36t, or go larger on both.
  1. Double Hex SS Chainring Bolts
    By Raybum in forum Singlespeed
    Last Post: 09-05-2013, 07:58 AM
  2. Going double chainring for MTB?
    By sklein in forum Bike and Frame discussion
    Last Post: 10-27-2012, 09:57 AM
  3. Using a singlespeed chainring for double setup?
    By fordohio in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-13-2012, 05:33 PM
  4. T2 chainguide for XTR 980 Double Chainring
    By bashtee in forum Intense
    Last Post: 10-26-2011, 10:48 AM
  5. Replies: 41
    Last Post: 05-03-2011, 07:20 AM
