Results 1 to 3 of 3
    T , V , & K Rider
    Double/bashguard vs triple crank advantages for 6" travel frame?
    Besides the obvious advantage of a bashguard and abit more clearance of the crank without a big chainring, why do you riders that use them like this setup? I plan on building up a 6" travel frame with a 6" fork( Fox 36) in front! The only disadvantage I can see is not having the big chainring for pedaling down hills and such for higher speed! I have only used triple cranks so far mainly on XC style frames! Just wondering if its worth trying a double because I am building it for more for going over stuff and drops and such than for speed! Thanks! TIG.
    Reputation: GearHead's Avatar
    Dec 2004
    Quote Originally Posted by TIGMAN
    Another major advantage is you can use a short cage rear derailleur with this set-up since the rear derailleur doesn't require as much capacity. This has two benefits: increased ground clearance of the chain itself, and a reduction in chain slap on the chain stay due to increased chain tension.
    T , V , & K Rider
    Chain slap!
    Quote Originally Posted by GearHead
    Yeah, that makes sense, I suppose you would also get a abit snappier gear shifting as well? I wonder if this would also help reduce the chain rubbing on bigger tires such as 2.5 Nevegal in the granny gears? I had this problem when I was running 2.4 Panaracer FR tires on one of my older bikes which had triple crank and long cage RD!!! TIG.
  1. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  2. How about Blur vs. Mount Vision?
    By Jetstream in forum Bike and Frame discussion
    Last Post: 10-24-2004, 08:12 AM
  3. Recommend me a 6" travel frame.
    By FISHLEG in forum Downhill - Freeride
    Last Post: 07-12-2004, 12:35 PM
  4. 2 Questions- NEW frame & New crank needed?
    By mtnbikerboy360 in forum General Discussion
    Last Post: 02-26-2004, 05:15 PM
