    Great... another hobby...
    Does truvativ make an 8 speed crank set?
    Umm.. my question is in the title. Thanks!
    Ride to the base... Climb to the top... Life is peachy!
    Titus FTM
    Felt Q-620
    Freshly Fujified
    Reputation: Call_me_Clyde's Avatar
    If they do.....
    It's going to be an OEM or lower end crank that is put on new, low end bikes that still run 8speed drive trains. Frankly, I wouldn't worry about whether the cranks are designated 8 speed or 9 speed. I believe the differences are so minimal that you can get away with using a "9 speed" designated crank on an 8 speed dirvetrain.
    Can someone back me up on this?
    Bob
    'If Wal-Mart sold parachutes, who would jump?' Frank Havnoonian (quoting his father) Drexel Hill Cyclery
    Jan 2005
    You should have no problem running a 9 speed crank on a 8 speed drivetrain.
    But I should probably expect significant front derailleur adjustment correct? I suppose I should expect this regardless huh?
    Titus FTM
    Felt Q-620
