Results 1 to 7 of 7
    does SRAM XX1 Crank GXP work with Shimano XT External BB
    Hi All,
    I currently are running Shimano XT M785 crank-set. I just bought XX1 crank-set and plan to run 1x10?
    do I need new BB for XX1 crank or can I use XT external BB that I currently have?
    Thank you for your help
    E
    You need a GXP bottom bracket.
    Quote Originally Posted by spsoon View Post
    This man said it. Do yourself a favor, and skip the Truvativ bracket. Cough up the extra dough and grab an Enduro. Better sealing, better life, less problems.
    Mulleticious
    Reputation: BigwheelsRbest's Avatar
    ^^ What does the "GXP" bit mean? Does it have a different crank diameter than the Shimano cranks?
    Formerly of Kent
    Reputation: Le Duke's Avatar
    "Crank diameter"?
    If by that you mean spindle diameter (the thing that connects the two crank arms), yes, it does.
    Death from Below.
    Mulleticious
    Quote Originally Posted by Le Duke View Post
    "Crank diameter"?
    Gotcha.
    Never trust a fart
    Reputation: frdfandc's Avatar
    Just to expand on what was mentioned above.
    Shimano uses a spindle that is 24mm in diameter across the entire length.
    Sram(Truvativ) uses a spindle that starts at 24mm at the drive side and tapers down to 22mm in diameter.
    So with a Shimano crank, you need to use a Shimano bottom bracket. With a Sram(Truvativ) crank, you need to use the GXP bottom bracket.
  1. Will a Sram x9 crankset work on a Shimano drivetrain?
    By Soccersmitty55 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-13-2012, 03:15 AM
  2. Shimano crank with sram components?
    By jcatier314 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-25-2011, 09:09 AM
  3. Will a Sram XO rear work w/ a Shimano shift pod?
    By Spongebob in forum Beginner's Corner
    Last Post: 07-12-2011, 04:37 PM
  4. Shimano Press Fit 10 speed crank and 9 speed external cup compatibility question
    By wildh in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-20-2011, 11:45 AM
  5. Shimano XT dyna-sys with sram crank
    By wton5456 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-09-2011, 06:44 PM
Members who have read this thread: 12
