Results 1 to 3 of 3
    Does it matter which side BB cup you remove first when removing a BB?
    Does it matter which side bottom bracket cup you remove first when removing your bottom bracket?
    Reputation: supersedona's Avatar
    Dec 2012
    I usually start with the non-drive side since that is a lighter/smaller piece and is often plastic. Once that is out it will sometimes make the drive side one easier. Of course if you are using a BB30 or other through axle type system then it is irrelevant which side first.
    '93 Giant Sedona ATX custom
    '93 Giant Sedona AtX aero-edition
    '73 Schwinn Suburban
    '95 Fuji Suncrest
    I see. Mine is a normal external BB, which I prefer over other BB standards. Thanks!
  1. removing drive side crank arm-stuck
    By hahdtail in forum Tooltime
    Last Post: 11-10-2012, 09:10 PM
  2. Side to side play Sun Ringle Charger 29er wheelset
    By mastakilla in forum Wheels and Tires
    Last Post: 03-18-2012, 07:02 PM
  3. Fox Float RLC Oil Change Damper-Side/Spring-Side Oil Bath Help?
    By zbear in forum Shocks and Suspension
    Last Post: 09-18-2011, 07:06 PM
  4. Replies: 3
    Last Post: 07-21-2011, 08:58 PM
  5. Removing stickers w/o removing rack paint?
    By jrm in forum Cars and Bike Racks
    Last Post: 05-20-2011, 08:25 AM
