Results 1 to 9 of 9
    Scallywag
    Does Chain Length Really Matter?
    I use a Med-Cage rear derailleur and when in the largest cog on the cassette the derailleur is angled forward, about 45 degrees. It seems other bikes I look at, when the derailleur is in the same position the derailleur is strait down. Novice mechanic so I may have jacked it up. The shifting is smooth but is there any disadvantage to having such a short chain? I know, I know... Let the jokes begin, I should have used an alias.
    _______________________________________________
    08 Intense 5.5
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by JDubKC View Post
    Yes, it does. You need to be able to shift onto and off of the big-big combo (even though you should not use it). If this is a suspension bike you need a bit more length.
    mtbtires.com
    On the big-big combo, 45 degrees forward is fine. It's about the chain length I run (also on a med cage). The advantages to a shorter chain (as long as it can still do the big-big combo) are less chainslap and less weight, with some also claiming better shifting.
    NWS
    NWS is offline
    Jun 2010
    It's not the length, it's how you use it.
    NWS
    NWS is offline
    Jun 2010
    But seriously... put the chain on your biggest front ring and biggest rear ring, and work the rear suspension all the way up and down. Disconnecting the shock (or letting all the air out) will make that chore easier. You don't want to ever get into a mode where the chain becomes the only thing limiting your suspension travel.
    Scallywag
    Quote Originally Posted by NWS View Post
    I think this is the helpfull info I was looking for. Cheers
    08 Intense 5.5
    Tool
    Reputation: Pedalphile's Avatar
    In my experience, the shortest chain you can safely run (per the guidelines above) is best.
    I can barely get my mouth around it.
    Quote Originally Posted by Pedalphile View Post
    I second that, too much chain lets the RD move too much and you end up picking up branches that can do very bad things:
    1. Break the derailleur
    2. Break the hanger
    3. Break spokes
    Does having a chain that is on the shorter side cause extra cross-chain friction when using the big big combo? On my 2x10 Epic 29er I shortened the chain because the chain dragged the chain stay in the small-small. I used the SRAM guide, big-big plus a link plus powerlink and now it seems like there is more friction in the big-big.
  1. Old components on new frame .2" shorter chain stay - chain length reduction?
    By DPDISXR4Ti in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-14-2011, 03:32 PM
  2. spoke length: does 2mm too short matter?
    By 3cb in forum Wheels and Tires
    Last Post: 07-28-2010, 08:24 AM
  3. New Chain Ring Problems - Chain Length??
    By dontheclysdale in forum Singlespeed
    Last Post: 04-19-2009, 06:58 AM
  4. Chain quality!? Does it matter? Differences between the UN-73, and the XTR 7701 chain
    By Sexyblackbmw in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-28-2007, 06:47 PM
  5. calculating chain length w/cage length
    By Slobberdoggy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-05-2006, 07:43 AM
