Results 1 to 17 of 17
    Reputation: mikeridesabike's Avatar
    Does anybody make a 9 speed 11-36 cassette?
    I swear I saw one on-line a couple of months ago, but when I went to buy one today I couldn't find it to save my life. I bought a used 29er which came with a 2 x 9 Middleburn crank that has a 27 tooth small ring up front. The 34 in the back isn't quite low enough for this fat boy to get up some of those Pisgah climbs. I hate to have to put a 3 speed crank back on as I really like the 2 x 9.
    Friends don let friends ride road bikes.
    http://www.facebook.com/mikebmiller
    turtles make me hot
    Reputation: NYrr496's Avatar
    I like turtles
    Reputation: shiggy's Avatar
    Dec 1998
    Nope. That is a 12-36.
    No production 9-sp 11-36 cassettes.
    mtbtires.com
    Always Learning
    Reputation: BruceBrown's Avatar
    Quote Originally Posted by mikeridesabike View Post
    Luckynino - Bikes & Parts: 9s - 11/12-36 Ti MTB Cassette
    Action Tec Home Page
    36 Tooth Cog for Mountain Bike Cassette 36T Sprocket | eBay
    RIP Friendgirl
    Reputation: Bordershy's Avatar
    If possible, replace the 27T chainring with something smaller.
    SPD pedals are an absolute menace to the well-being of the world, and ought be banned immediately.
    turtles make me hot
    Quote Originally Posted by shiggy View Post
    OOps... Sorry.
    I like turtles
    Thanks guys. 12-36 is just fine. And that 27 is the smallest ring Middleburn makes for that particular crank.
    In Transit
    If I remember right, that particular cassette was marketed as "designed for 29ers".
    Dec 1998
    Quote Originally Posted by GiddyHitch View Post
    Which was just and only that--marketing BS.
    mtbtires.com
    NedwannaB
    Reputation: JMac47's Avatar
    These were low end LX cassettes and there was something about recommending a steel freehub body to use these due to the extra torque applied, specially if used on a smaller diameter wheel. Can't imagine all 29 wheels had them, maybe on the lower end bike wheelsets.
    Wait whuuut, who did he tell you that!?!?....
    Dec 1998
    Quote Originally Posted by JMac47 View Post
    Because of the lack of a cog carrier. As with any individual cog cassette, it can eat into an aluminum FH body.
    Shimano did have a Deore level hub with a supposedly stronger FH body that they labeled as a "29er" product (quickly ignored as such).
    mtbtires.com
    NedwannaB
    Right. I didn't grab the "over torque" theory of the larger cog at first, thinking it would be less. Then realizing the "leverage" for a better term would be greater thus applying more force generated on the.
    I contemplated putting the 12/36t on my new(er) DT240 hubbed wheel but even only oyshing the scales at 140# thought otherwise and put on the XT hubbed wheel instead. "Whe'el" see how it does!
    RIP Friendgirl
    Mike, if your middleburn crank is external bearing & you have another bike with a shimano 9sp crank just swap them out? If it's a 64/104 bolt pattern you can use 22/32 chainrings that would work well with your 34-11 cassette & wagon wheels.
    Dec 1998
    Quote Originally Posted by Bordershy View Post
    Or get a new spider for the Middleburn. They have many options.
    mtbtires.com
    Santana sells a 11 36 ten cog set. The Shimano 629 hub has a steel insert splines like the old 750 755 HF07 HF 08 737 | Flickr - Photo Sharing! I can't find out if the 529 also has the steel splines it is advertized as a high torque hub. Wether they beefed up the ratchet mechanism or not I don't know.
    "Dish is illogical." Spoke of Vulcan.
    turtles make me hot
    Quote Originally Posted by zerodish View Post
    I have a 529 in front of me. The splines are steel.
    I like turtles
    Shimano CS hg 81 is 9 speed 12 -36 I believe and its close to 400 grams but its perfect for a 2x9 setup on a loaded touring bike with 50/34 rings. Triple bad, double better.
  1. Will an 8 speed rear derailleur work with a 9 speed shifter and cassette?
    By CyclesnIPAs in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-31-2017, 04:35 PM
  2. Will XT M772 rear der. 9 speed work with 8 speed shifter/cassette?
    By jh_on_the_cape in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-08-2013, 06:40 AM
  3. Does anyone make a 36t nine speed cassette?
    By 9.8m/s/s in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-11-2012, 09:48 AM
  4. 9 Speed MTB Shifters + Cassette, 10 Speed Road Rear Deraileur....??
    By joehspicer@msn.com in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-09-2012, 08:42 PM
  5. Anybody make an 11-34T 8-speed cassette?
    By Pollution Warrior in forum General Discussion
    Last Post: 04-01-2011, 06:59 AM
