Results 1 to 5 of 5
    Mar 2013
    Do i shorten my chain now?
    Went from 3 rings up front to 2.
    Old setup 42/32/24
    new setup 36/22
    Can I shorten my chain a bit? This would be perfect timing as the chain is already off the bike. Also noticed extra chain slap on these last couple rides.
    thanks in advance for this noob
    Last weekend in Moab:
    Reputation: MSU Alum's Avatar
    You probably should re-measure the chain. I expect you'll need to remove a couple of links to get to the proper chain length since the overall maximum chain length is shorter with the smaller chain ring up front. SRAM Chain Sizing - YouTube
    Mar 2013
    a little search helped immensely. my chain is too long. thanks again guys!
    Hmnn i think i also need a smaller FD cage as well.
    Feb 2013
    beatercity, where did you find that info? I recently went from 3 to 2 up front as well and it's chainslap city for me. Share what you've learned. Thanks!
    Reputation: SlowMTBer's Avatar
    Dec 2011
    One of the most accepted ways (I always thought it was the proper way, but have heard other procedures) to size your chain is to place the chain on the bike without going through the derailleur, on the biggest ring up front and in back, then add 2 links to the amount of chain required for the above process. So yes, the OP only needed enough chain for the 36 tooth up front, instead of the original 42 tooth chain ring.
    You could probably get away with a mid-cage rear derailleur also, but if your front rings are spread as far as the OP, it might be borderline.
    I went with a mid-cage when I dropped the Big Ring up front, and I was 24-32-42 before. In my checking, if I go 36 for my second ring, I can still get away with the mid-cage.
    2011 Trek Rumblefish 1
  1. Shorten chain after dropping big chainring?
    By llamma in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-26-2012, 10:16 AM
  2. Shorten chain for med cage and 1x9 ?
    By natzx7 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-15-2012, 06:11 PM
  3. Just curiuos, if my rear deraileur breaks, can I shorten the chain to make it an SS?
    By ecub in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-23-2011, 03:13 AM
  4. need to shorten my '06 GF3
    By fast14riot in forum Shocks and Suspension
    Last Post: 07-29-2011, 02:00 PM
  5. Replies: 29
    Last Post: 03-06-2011, 09:31 AM
