Results 1 to 7 of 7
    Different spacing for xtr(m970) small ring?
    I read recently that the m970 cranks use a different spacing for the small ring. Can anyone confirm this? If so, how much diff than a standard small ring? I want to use non xtr (race face) rings on this crank...
    Thanks...
    Former Bike Wrench
    The M970 uses the standard 64mm spacing for the granny, previous XTR models did not.
    I believe there is an offset to the teeth, which is what the op is talking about.
    Just checked my 970's, they're about 3mm offset from 'centre'. I'm assuming you don't have rings on your crank now to check.
    Sorry, I wasn't very clear with my question. Yes, the offset is what I meant, not the bolt circle.
    You say 3 mm towards center. So a 3mm spacer under a ring w/ no offset would be in close to the same spot? Or maybe a better way to ask, what is the "correct" spacing of rings from small to middle? 2x9 with 9spd chain.
    Thanks again...
    Former Bike Wrench
    Quote Originally Posted by AlexRandall View Post
    Gotcha ya
    Ok, I've done a re-measure, as the previous post was a 'by-eye' type approximation. I put a BB spacer on the offset section of the ring and its a bit wider. As these are 2.5mm I would say 2mm is what you're looking at. Its hard to get an exact figure here as Shimano could have it 1.8mm out or something just to make it hard to fit aftermarket rings (as its done with XTR from the beginning).
    If I was you, I'd just buy an XTR small ring or a Blackspire XTR-compatible ring and have done with it. Small rings are 'cheap' and I've never had a lot of luck with anything which has been jury-rigged .
    Carbon Ti sell kits
    Carbon Ti sells double kitsXTR FC-970 cranks $200 euros and it list a 2 mm spacer they also have instructions on there web site, shimano sell bolts with spacers for the two chain ring FC-M800-2 crank set Part # Y-1FB 98010
    http://www.carbon-ti.com/index.php?p...&Cod=XDTEK4028
    Hope this helps!
    Attached Thumbnails Attached Thumbnails Different spacing for xtr(m970) small ring?-x-double_kit_ti_evo_40_26_red.jpg
  1. SLX 32T ring fit on XTR M970 crank without modification?
    By 6thElement in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-06-2011, 02:15 PM
  2. M970 granny ring - only two bolts OK?
    By JHANguyen in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-07-2010, 06:43 PM
  3. Am dual ring for XTR M970, Which is best
    By mimi1885 in forum All Mountain
    Last Post: 04-18-2010, 03:44 PM
  4. XT M770/XTR M970 composite middle ring
    By SSBonty in forum Weight Weenies
    Last Post: 07-16-2008, 06:10 AM
  5. Replacing the M970 XTR middle ring
    By steelduck in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-25-2007, 07:25 AM
