Results 1 to 3 of 3
    zul
    zul is offline
    Will Guide for Beer
    Reputation: zul's Avatar
    Different Opinions
    Just had the LBS build up a new rig for me and 2 of the mechanics have different opinions. I had to swap my old parts onto a new frame. My chain is stretched but the cassett and front rings are in really good shape. Mechanic #1 says put a new chain on. Mechanic #2 suggests sticking with the old chain as chainging the chain could lead to other problems and skipping.
    Is there a right or wrong way to go? I have one ride on new steed. No problems on 2 hour ride.
    By the way, both mechanics are quality / top notch.
    thx.
    If lovin you is wrong, I don't wanna be right
    Reputation: liam2051's Avatar
    ok, somtimes running new componentry on old can cause skipping jumping problems it does happen. so running a new chain may need you to buy a new cassette and front ring, or it could work and u might be in the lucky few. but if ur chain is had it then id be tryin a new one on the old gear and just go from there
    Quote Originally Posted by zul
    thx.
    Replace the chain, it's worn and it could damage the chainrings. If you get skipping, replace the cassette as well.
