Results 1 to 5 of 5
    Buzzrider
    Guest
    New question here. Difference between Sram PC-99 and PC-991
    I hope this question is not redundent. What is the difference between a Sram PC-99 chain and the PC-991. Same price different looks. The Sram website is of no use at all.
    Are you talking to me?
    Reputation: damion's Avatar
    Jun 2003
    Is there one?
    Good question. Model's changed slightly? I beleive they are the same, or at least VERY close.
    gfy
    Buzzrider
    Guest
    Quote Originally Posted by damion
    From the pics they seem to be quite different. I am using a new Shimano cassette, with a RaceFace Deus crank. Just wondering if one would be better than the other. Seems odd that the Sram web site gives no specs for the PC-991.
    PC-99 in the first image and PC-991 in the second.
    Cereal Killer
    Reputation: chadmeeh's Avatar
    Jan 2005
    I've used both the older models, and the newer ones, and the only difference I've seen, is that on the new ones, the outer links have a slight "buldge" to them. Makes them a little noiser when there's a crossing (small cog, small chainring), but nothing to worry about. Freaked me out when I first heard it, but quickly figured it out. Hopefully it won't pre-maturely wear any parts out.
    3 "fiddy" for short
    Reputation: be350ka's Avatar
    Dec 2004
    Quote Originally Posted by chadmeeh
    Don't run those extreme gear combos and you should'nt have any abnormal wear (small/small, or Large/Large). They are not great for your drivetrain no matter what chain/components you are using.
