Results 1 to 5 of 5
Thread: DH Big Ring
    Reputation: bgfthntr's Avatar
    New question here. DH Big Ring
    will a DH 36T ring work as a big ring for a triple even without pins?
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Depends on how well its set up . It can work , pay extra attention to your f.d. , prob. not work as well as ramped and pinned chain ring though .
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by bgfthntr
    In most cases they work just fine. Pins/ramped are not "needed" for shifting. I rarely use ramped rings but I also learned to ride pre-ramps/indexing and know how to finesse a shift when needed.
    mtbtires.com
    Thanks....
    I put a DH 38T in place of my 44T Outer Ring and it works fine. It releases a little slow when shifting out but I just reduce pedaling pressure. For me it's a much more usable setup.
    38T, 32T, 22T
    Dec 1998
    Thanks....
    38T, 32T, 22T
    Cool! That is the way it works, and your drivetrain will be happier because you have learned to finesse your shifts.
    mtbtires.com
