Results 1 to 3 of 3
    derailleur wheel hangs low
    the part on the derailleur that hangs down, (i think called the jockey wheel) seems to always hang really low, ive seen pictures of derailleurs where its pulled up tighter and im wondering if this is something i can adjust, or is this just how some are?
    the reason im looking into it is because my chain seems to have a lot of slack on it and im wondering if theres not enough tension. I get pretty bad chain slap against the frame on hops and small drops and it also slaps against the ground pretty bad, which i didnt even realize until i took a video of me doing a 6-8" bunny hop
    its a 2006 rockhopper, and i believe a SRAM x5
    Reputation: Lurchlee's Avatar
    double check chain length
    then try adjusting your rd
    Nov 2008
    Two separate issues. First of all, if the RD has enough capacity it'll take up all the slack in the lower loop with the small/small combination. The spring isn't tight, so it'll get the lower loop horizontal, but not much more before hitting the stop.
    The chain slap happens because the chain is so close to the chainstay, when on smaller sprockets, and there will never be enough tension to keep the upper loop tight when coasting. It happens with almost all bikes, and the solution is a chainstay protector. There are many you can buy, or you can improvise something with vinyl tubing and cable ties.
    As to the overall derailleur height. That's controlled by the B-screw, (top rear of the RD). This sits against the derailleur stop, and can be adjusted to bring the RD up or down. You want the upper wheel as close to the sprockets as possible for better shifting, but there has to be one inch of chain between the pulley and sprocket at all times (check for each sprocket). BTW- that's one inch along the chain, not straight across from pulley to sprocket.
    fb
    www.chain-L.com
    The key to solving any problem is to understand and address the underlying cause.
  1. Guy hangs himself on the 52 westbound
    By alien4fish in forum California - Socal
    Last Post: 04-15-2011, 09:09 PM
  2. Derailleur Jockey Wheel Issue
    By cgreen9761 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-04-2009, 08:36 PM
  3. Spring hangs on in So Cal
    By mtroy in forum Passion
    Last Post: 07-13-2008, 09:09 PM
  4. Derailleur sucked into wheel
    By Buzzrider in forum Rocky Mountain
    Last Post: 06-30-2006, 08:05 AM
  5. Derailleur sucked into wheel (crosspost)
    By Buzzrider in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-27-2006, 03:57 PM
