Results 1 to 5 of 5
    Apr 2014
    Derailleur and Shifter Issues
    So for a while now I have been having trouble with my rear derailleur coming out of tune as I ride, especially on rougher terrain. The confusing part is that it stops wanting to shift into a higher gear (i.e. chain moving down the rear cogs). So based on my knowledge this would mean that my cables are getting tighter as I ride, and I have to constantly adjust my rear derailleur by loosening the cable a few times every ride. This is confusing because I don't know how my cable could tighten itself as I ride; if anything I would expect it to get looser. More recently I was getting it back in tune after a ride and the thumb shifter started getting really stiff. When i go to shift into 1st or 2nd gear in the rear it takes a great amount of force. I am not sure if the two are related or not, but they are both aggravating. Does anyone have any advice or knowledge on these issues?
    A few things I have checked/tried already,
    1. top and bottom limits on the derailleur
    2. cables ability to move freely through the guides, may need some lubricant, haven't added any in a while
    3. derailleur's ability to move smoothly by working it with my hand
    Reputation: J.B. Weld's Avatar
    The cable isn't tightening itself during the ride, it's hanging up due to stiction somewhere along the line. This sounds like a classic case where new cables and housing will make everything right again. Cables can feel fine when checking by hand but rear derailleurs are very sensitive to any imperfections.
    I brake for stinkbugs
    Apr 2014
    Thanks for the advice, I had thought that might be the issue. I will look more into that.
    If it's a full suspension then check the routing and length as you replace the cables and housing.
    Magically Delicious
    Reputation: Cleared2land's Avatar
    As above, I'm lending support to the cable replacement theory.
    A bad day of cycling is better than a good day at work
    Work Truck - Dassault Falcon 7X
  1. XT 11 Speed Shifter Issues
    By Mark194 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-27-2016, 12:12 PM
  2. Shifter Issues
    By big-w in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-23-2015, 07:51 PM
  3. Shimano STX shifter issues (1995-ish)
    By Eric Z in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-01-2015, 04:17 PM
  4. shifter or derailleur?
    By circlesuponcircles in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-07-2012, 07:21 PM
  5. A new derailleur and shifter
    By amir1234 in forum Downhill - Freeride
    Last Post: 01-26-2011, 03:46 AM
