Results 1 to 36 of 36
    MTBR Demi-God
    Reputation: anirban's Avatar
    Derailleur Hanger Alignment- Tougher Than Rocket Science?
    Hello!
    I just bent my derailleur hanger . So I thought that its not a big deal- I will just go, get a replacement derailleur hanger, and with the help of Park's website, I will put it on under 10 minutes.
    So I check out Park's repair website on derailleur hanger alignment, and I felt like I fell down a abyss.... and I am not in a position to invest in a derailleur alignment gauge!
    I was thought that all I needed to do was use a hex wrench to remove the derailleur from the hanger, remove the damaged hanger, place the new hanger, and install the derailleur back.... but what the heck is this in parks' website?
    I do have a mechanical background, and I would consider myself to be mechanically inclined. But I have a feeling that installing a derailleur hanger is out of my league...
    Any recommendations? Thanks a lot!
    Incase you are wondering the park website: http://www.parktool.com/repair/readhowto.asp?id=39
    EDIT: when the hanger bent on the trail, I was able to roughly straighten it out, and adjusted the indexing on the RD- and its been working beautifully. But the hanger has the stress/strain marks where it was bent, so I am guessing that it will not be able to hold much longer.
    nachos rule!
    intentional weak link
    given that it's a replacable hanger that's bent, i'd say your frame alignment is fine. slap on the new one and go ride...
    plus a change, plus c'est la m'me chose - alphonse karr
    MTBR Demi-God
    Quote Originally Posted by supercorsa
    Yes, I do know for a fact that my frame is not damaged/dented at all. Its the hanger that has taken all the stress.
    So I can just screw a new one in (without any alignment calculation) and be good to go? And does the park tool's website actually shows how to align the frame?
    Thanks.
    Vaginatarian
    you should be able to bolt on the new one and go, no adjustment. the park instructions are for straightening the old one using their tool(which is a good investment $40)
    as far as the old one , unless it cracks or breaks its re useable (I would keep in my bag as a spare)
    MTBR Demi-God
    Thanks for the info guys! I had talked to a LBS today, and they said that it would cost me 45 bucks to replace the derailleur hanger
    Now I try my best to support the LBS, but it seems like a ridiculously high price to just swap a hanger.... so I guess I will partially support them- by purchasing the hanger from them, and installing it myself.
    Vaginatarian
    Quote Originally Posted by anirban
    see
    now spending $40 for the tool doesnt sound so bad huh?
    Meh.
    Reputation: XSL_WiLL's Avatar
    45 has to be for the part, installation, and adjusting the derailleur. Or I hope so anyways...
    MTBR Demi-God
    Thats the labor. The part (hanger) is extra 20 dollars. Considering that the installation takes no more than 5minutes, that 45bucks translates into 9 bucks/minute or $540/hr.... and I am sitting here designing satellite launch vehicles for shamefully less than that....
    One question- do different frames/brands have different hanger designs? or is the hanger the common shape- "one hanger fits all frames" kindda thing?
    Old man on a bike
    The hanger is pretty much bike specific. Try looking around here http://derailleurhanger.com/
    suum quique
    Vaginatarian
    if its Specialized you can get it on their web site, I think its $15
    Reputation: Joules's Avatar
    here we learn a bigger lesson: park is in the business of selling tools, not providing free advice. Keep that in mind when reading their repair help pages - I've never seen really bad advice, just some things that suggest you need more tools than actually required.
    Reputation: xl_cheese's Avatar
    The park tool is nice. Even brand new frames can have hangers out of alignment. I've also seen newly replaced hangers slightly out.
    Reputation: MikeDee's Avatar
    Quote Originally Posted by xl_cheese
    I agree. I've aligned 2 bent hangers so far; one after the LBS supposedly aligned it and it was noticably off. The tool has paid for itself.
    Vaginatarian
    Quote Originally Posted by Joules
    I think the bigger lesson we learn here is some people (joules)are never satisfied,
    I cant believe you are finding fault with a company who publishes a great workshop manual AND puts it online so anyone can use it free of charge. What, just because they recommend their own line of tools? give me a break. why dont you put your own manual online and you can tell us all your great secret tips that dont use Park tools
    what the hell are you talking about?
    I'm not complaining that they recommend their own tools, I'm not even really complaining that they recommend their own tools that aren't even necessary, I was pointing out that a newb shouldn't read their online manual, take it as gospel and run out and buy everything it says is required for the procedure, because frequently, as the OP discovered, they say you need tools that you don't.
    and amen to that
    I think you should read Barnett's Manual before criticising Park. Barnett requires about every specialty tool that you can think of. Just about every repair text that I've read calls out the use of specialty tools.
    Vaginatarian
    lets see
    the link was for deraillier alignment
    which tools did that park link spec.? a stand (possibly dont need but nice to have)
    a hanger adjuster ( how else would you straighten the hanger perfectly)
    and hex wrenches( good luck getting the derailliier off without )
    the link was for checking and straightening the hanger, now if you only want to replace the hanger, all you need is a wrench but thats not what the link was for.
    Ive used the park manual and several others and Ive yet to see what extra tools they are pushing. can you work on a bike with a screw driver and a multi tool? sure but workshop manuals recommend the best way they think it should be done, and to critisize park for recommending their own tools is ridiculous, especially when they put the manual online for free
    If you ride a lot meaning you will crash once in a while the tool is the way to go. In fact you will find yourself aligning all of your friends bikes too and all of the ghost shifting they used to live with will be gone as well. Money well spent to maintain your ride. If you can's afford the $40-$50 tool for your $4500 ride then go halves with a buddy. Easy to use and well worth the cost in my humble opinion.
    Harrumph
    Reputation: G-reg's Avatar
    Quote Originally Posted by MikeDee
    Actually I’d say about 99% of all hangers come tweaked from the factory. The last few shops I worked at I used that nice Park Tool (and find another company that makes that tool…) on just about every bike I touched. It was rare for derailleur hangers to be aligned, especially replaceable ones. People underestimate the importance of having the derailleur properly aligned. And if I had to guess, I’d say that your new replacement hanger is not going to be perfect. And the 40.00 tool is definitely worth it if your LBS wants 45.00 to install it. The poor man’s derailleur alignment tool is to hold something long and straight up against the outside of it and see if it is in line.
    Slowly slipping to retrogrouchyness
    Old school BMXer
    Reputation: Blaster1200's Avatar
    Agreed! Many GT frames for years came with the hanger badly out of alignment.
    I've been wanting to buy one of these tools. They really do come in handy. In the meantime, if you know what to look for, you can do a pretty damn good job with a large adjustable wrench (Crescent), which is what I've been doing.
    Not only look for the bottom to be bent inward, but also make sure it's not twisted. The Park alignment gauges takes all angles into consideration.
    May the air be filled with tires!
    Feb 2007
    The park tool is nice, but I have aligned many a derailleur hanger via the big adjustable wrench method. Gentle on the MONGO power.
    You could also cobble together a substitute gauge with an appropriate threaded bolt and a bar. the main "trick" is to check that the hanger is parallel to the rim. Some rubber bands and a chopstick make an OK pointer.
    Some blue locktite on the new hanger bolts is a good idea.
    willtsmith_nwi
    Reputation: willtsmith_nwi's Avatar
    Jan 1970
    Thats a ripoff. Most shops charge $20 for the hanger and it's a 10-15 minute job to replace it.
    1) remove chain.
    2) Remove derailleur
    3) Remove hanger (you'll need a chain nut tool for this)
    4) Screw in new hangar
    5) screw in derailleur
    6) Put the chain back on.
    I have a cool LBS guy who let me buy hangers from him at $10 apiece. This should give you an idea of what derailleur hangers cost the dealer.
    If you're going to be dealing with this alot, you may want to just get the tool. Of course, for the tool to work you need your wheels to be true.
    MTBR Demi-God
    Quote Originally Posted by willtsmith_nwi
    1) remove chain.
    Huh? I didnt remove the chain, I didnt use a chain nut tool to remove the hanger....
    All I did was remove the derailleur from the hanger using a hex wrench, then removed the hanger using the same hex wrench, re-used the screw, and slapped the new hanger in, and screwed the derailleur back in the new mounted hanger.
    Then I did some minor adjustments to get the derailleur tuned up, (because I had tuned it before to offset the bent derailleur) and it was good to go. Its been working fine.
    Do you think I made a mistake somewhere while installing the hanger?
    willtsmith_nwi
    Jan 1970
    Nutting it
    Yeah, I suppose you really don't need to remove the chain, it's more convenient though
    The bolt that holds the derailleur hanger to the frame screws into a threaded hollow nut. It's the same type used on chainrings. There are two cutouts along edge of the nut that allow you to hold it still so you can tighten the bolt into it. It's my assumption that all derailleur hanger work this way. Someone please correct me if I'm wrong.
    If you got the derailleur hanger off without a chainring nut, power to you. But when you put it back on it may not be sufficiently torqued as so it does not come loose without using a chainring nut tool.
    Vaginatarian
    Ive never seen a hanger that used that type of bolt, in fact you have to be careful about torqueing the hanger bolt on specialized because they use an alloy that will strip very easily
    ups and downs
    The new Giant Maestro FS bikes use the same chainring style hanger mounting bolt.
    MTBR Demi-God
    Quote Originally Posted by dan0
    Hey Dan, pardon me if its obvious, but what kind of bolt have you never seen on a hanger- the hex bolt, or the chain nut bolt?
    You do not need to have a true wheel to use the tool. Follow the directions and pick a point on the rim, say the valve hole. Rotate that to where you measure as you go. Viola. You are always measuring to the same point. It is however important to have the wheel bearings properly adjusted.
    Vaginatarian
    Ive never seen a chain ring bolt /nut on a deraillier hanger
    Reputation: Walt Dizzy's Avatar
    Aug 2003
    Repair job
    What looks like a chain ring bolt/nut combo is probably a repair for a stripped hanger bolt hole.
    Walt
    willtsmith_nwi
    Jan 1970
    Yes they exist!!!
    Quote Originally Posted by Walt Dizzy
    Walt
    Yeah, before Giant sent me those replaceable dérailleur hangers they accidentally stripped the threads. Then they drilled them out and provided a backing nut for the bolt to go into. <--- Sarcasm
    These hangers do exist despite you're (in your apparent omniscience) never having seen one. If your all knowingness wishes to see it, he should visit a Giant dealer and peak behind the dérailleurs.
    MTBR Demi-God
    Its good to know that there are different kinds of derailleur hangers available. Could you post a picture of it so that I can get an idea of how it looks like? I just want to make sure that I didnt screw mine up by using a hex wrench. Thanks!
    "Winners never quit. Quitters never win. But those who never win and never quit are idiots."
    willtsmith_nwi
    Jan 1970
    Sorry I can't. Is a picture of the hanger enough. I don't own the bike anymore, but I have a couple hangers for it ;-)
    MTBR Demi-God
    That would work! Thanks
    Music & Bikes
    Reputation: fokof's Avatar
    Hello!
    I just bent my derailleur hanger . So I thought that its not a big deal- I will just go, get a replacement derailleur hanger, and with the help of Park's website, I will put it on under 10 minutes......................
    ...................Any recommendations? Thanks a lot!
    Buy a Rohloff Speed hub.....
    "There is a big difference between kneeling down and bending over" -FZ
