    flurker
    Reputation: Venison's Avatar
    derailleur cable housing
    looking for opinions on best derailleur cable housing (I have an xt drivetrain)
    and best practices & products for cleaning, maintaining, & lubing
    High Gravity Haze
    Reputation: Spec7's Avatar
    May 2000
    I've always done well with lined Shimano and Jagwire housing, o-ring ferrules, and basic cleaning of the bike. I lubed my cables once, 15 or so years ago. That was a mistake; please make note of this.
    dru
    dru is offline
    I've always used white grease on the inner wire, but recently tried silicone spray. I like Jagwire and shimano housing too. Generally have decent life out of the stuff. I change the outers only every couple of years, the inners seem to last longer.
    Drew
    occasional cyclist
    Last time I switched to using brake cable housing- plenty of room for the cable to move in.
    I trimmed down the ends a bit to fit shifter caps on since the brake caps had a larger diameter hole. Works great.
