Results 1 to 10 of 10
    Derailer and Chain Length
    I switched from a long cage XT to a med cage XT. Should I remove links? The chain is measured big/big rings plus 2 links with suspension distance taken into account. It seems alittle long.
    Reputation: dhpimp's Avatar
    Yes, you will need to remove a couple links if you are running a triple. If you are switching from a triple to double then re-measure your chain length in the big/big+2 combo.
    Quote Originally Posted by dhpimp
    I apologize, this may sound dumb but some people use the word couple loosly and do not mean exactly 2. Please confirm that I would measure big/big + 0.
    Know any good trails?
    Reputation: Ouchies's Avatar
    May 2005
    I read on these boards that the formula works for all derailleurs regardless of their lengths. So, big/big + 2 (no derailleur involved in the measurement.)
    Me: "You're welcome to sleep over here in the A/C."
    Her: "I appreciate the offer, but I will just sleep in the tent."
    Reputation: Wombat's Avatar
    Quote Originally Posted by Ouchies
    I agree, both SRAM and Shimano say to use the big/big approach plus 2 links. You don't warp it around the derailleur when setting the length. This works fine on both my long and medium cage derailleurs.
    Wombat
    If you make your chain big/big+2, should you be able to shift to the big/big combo? I know you "shouldn't" do this but ...
    My LBS installed a new chain and there ain't no way it will shift to big/big.
    Anyone?
    a e i o u and sometimes y
    Reputation: Brizn's Avatar
    Mar 2006
    I'm interested for more response as well....as I've heard big/big+2 and have heard the "bottom-pulley-at-4o'clock-position -in-big/big" to measure chain length.
    On MTBR hiatus :(
    Quote Originally Posted by WildJackal
    Yes. That's the whole point behind the "big-big" method: just enough chain to safely shift to big ring and big cog and not break anything.
    Like Wombat wrote, the derailleur isn't involved in this process, so cage length has no impact on chain length.
    <img src="http://www.booboodog.net/images/chainlength.jpg">
    speedub.nate
    MTBR Hiatus UFN
    Time flies...
    Reputation: xjbebop's Avatar
    just make sure your new derailleur won't be maxed out in the big/big setting (for safety's sake, but never shift there...). Break your chain, thread it thru everything while on the big/big gears, and pull it together by hand. You'll see when the der is stretched to max, then back it off a link or two...reassemble the chain at that point/length.
    ...you'll most likely find that it's about the same length as the standard big/big measurement mentioned earlier...for future reference.
    ...every day sends future to past...
