Results 1 to 2 of 2
    Deore XT Front Derailleur won't click into place
    I just installed my front derailleur but I can't get it to stay aligned with the bigger chain rings. When I go to shift it up onto a bigger chain ring the derailleur moves the chain up temporarily but the derailleur doesn't lock into place. Is it just a tension issue or is it something else?
    Former Bike Wrench
    Derailleurs do not click into place, shifters do.
    Its likely you have the high (H) limit screw set wrong. Back it off 1/4 turn at a time and try the shift onto your big ring until the shifter can hit the 3rd get indent.
