Poll: What to do for a shifter?
Be advised that this is a public poll: other users can see the choice(s) you selected.
Results 1 to 15 of 15
    Reputation: Hardtails Are Better's Avatar
    May 2005
    Decisons, Decisions.....
    The XT shifter on my XC bike crapped out on me yesterday, and it's replacement time. Soooo..... what do y'all think I should replace it with? I currently have an XT mid cage RD by the way. All the options above refer to the trigger variants of their respective shifter.
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    No vote:
    I like Sram shifters because you use them with thumbs only. I believe X9 and X0 are not compatible with Shimano, you need the Attack or the Rocket (X7 and X9 equivalents, cannot remember which is which).
    Love My XTR Shifters...
    I love my XTR's, if you were unhappy with the XT for whatever reason you can use this as an excuse to upgrade. Otherwise just get the right side replacement (and check ebay if you go this route).
    ~ Fred
    Chrome Toaster
    Reputation: Hecubus's Avatar
    An XTR right only gets you a full metal thumb paddle and the ability to use bar end shifters. Ih and its gray. If you need none of these, get another XT. BTW, what happened to youir XT? Are you sure its just not filthy inside or did you break it?
    Mar 2006
    I recently switched from XT to SRAM Attack, and am very happy with the results. It took a few rides before I was used to the shifting (and stopped shifting the wrong way every time I came to a hill). I think I'm an SRAM convert now.
    May 2005
    Quote Originally Posted by perttime
    No vote:
    I know. The poll says that the SRAM shifters would require a SRAM RD as well.
    Quote Originally Posted by Hecubus
    The tip of one of the ratchety bits broke off. I took it apart to check.
    Reputation: pspycho's Avatar
    Aug 2005
    Similar to my post, but not exactly...
    Hardtails Are Better,
    See this post: SRAM X.7 vs. Shimano Deore XT?.
    I couldn't decide on an XTR Rear vs. SRAM X.9 - I went with the SRAM and so far (2 rides) I'm liking the switch. I also like how adjustments are made, shifting pattern, etc.
    2015 Specialized FATBOY EC70 Seatpost & Bars SRAM X7/Wolf 42T 1x10
    2016 Specialized DIVERGE Expert X1 SRAM 1x11 Force
    Paste eater
    Reputation: Jwind's Avatar
    Mar 2006
    Take the opportunity to check out SRAM if you havn't already. X.9 is an upgrade fro XT if you ask me... It's cheaper than XT ain't it?
    May 2005
    Double post.
    May 2005
    X.9 is a couple bucks cheaper for the whole setup, but I wouldn't need a new RD for XT.
    local trails rider
    Aug 2005
    Keep the XT deraileur and get Sram Attack or Rocket, the Shimano compatible shifters.
    Reputation: dhpimp's Avatar
    You also get 3 bearings in the XTR instead of 2 (XT).
    Quote Originally Posted by Hardtails Are Better
    You could always go the absolute least expensive route and replace just the main lever assembly - aka: the mechanism only.
    If your happy with what you have, why switch? If you want to switch to try something new, then you know what to do Otherwise, don't fix what ain't broken. I personally can't stand the ergonomics of the Sram triggers.
    May 2005
    Quote Originally Posted by dhpimp
    A real deal breaker there.
    Believe it or not, that actually costs $6 more than the whole shifter from QBP.
    I am currently suffering from a severe case of upgradeitis. However, I think I am going to just get a new XT shifter and be happy with that.
    No good in rock gardens..
    Reputation: Sideknob's Avatar
    Rapid Rise sucks. Just get some X9's and a new X9 rear mech.
    Less isn't MOAR
    May 2005
    Quote Originally Posted by Sideknob
    I rock high normal rear dereilleurs. I hate RapidRise with a passion.
