Results 1 to 6 of 6
    Reputation: mike29erss's Avatar
    Caution;  Merge;  Workers Ahead! crankset suggestions for my bike.
    ok i have a question about the size that i need. what would anyone think i should use and what specific sizes. i wanna go with a two by ten and i only have 500 dollars to spend on it. thanks i have an xtc 29
    Never trust a fart
    Reputation: frdfandc's Avatar
    If you want a budget friendly crank that will leave you more than $300 left, go for the Sram S1400 2x10 crank.
    Or you can go with Sram X0, X9, SLX, XT, XTR. Take your pick.
    Gearing is going to depend on the terrain you ride.
    thanks man i thingk im goint to get the xtr m985
    I have a Cannondale Carbon Moto.. It has a Truvativ Sram GXP1 crankset on it.. What do you think? Should I replace it?
    44-32-22 170mm
    for an all mountain, i would suggest the trail version of the xtr m980 or if you wanna go under 200 dollars then ur gonna replace the crank either by the same quality or cheaper and then u might have issues and all that. if i were you, i would keep the one u have on and then when its worn or damaged i would replace it. or if u really wanna replace ur crank you could look for a used but really good crank on ebay.
  1. New crankset suggestions!!!!!
    By Jodyc in forum 29er Bikes
    Last Post: 03-23-2010, 11:42 AM
  2. Drop bar, disc brake, triple crankset bike - suggestions
    By Wheeldog in forum Bike and Frame discussion
    Last Post: 08-25-2009, 06:13 PM
  3. please suggestions for a crankset
    By colker1 in forum Vintage, Retro, Classic
    Last Post: 03-19-2009, 01:45 PM
  4. 22/32 crankset suggestions
    By synthesis in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-17-2006, 10:07 PM
