Results 1 to 14 of 14
    Crankset: Square-Taper vs Octalink
    ok guys, i have to change my old crankset whit a new one, but i have only one of two options, a Square-Taper Crankset with the same chainring size like my old one or an Octalike Crnakset but has a smaller chainring size than my old one..they both have the same price..
    www.derbyrims.com
    Reputation: derby's Avatar
    The octalink is most likely stiffer than square taper, bringing more sense or feel of power transfer and traction.
    Generally smaller rings for sit and spin, bigger rings for stand and mash. The common 22, 32, 44 triple rings cover both styles of riding well.
    If you are changing only the crankset, then you will need to replace with whatever you have now. If you do the bottom bracket as well then you have the choice.
    Square taper has more likelihood to be flexi (if you can manage to identify the flex amongst all the other flexing parts on the bike and your own fitness levels - many can't)
    Octalink has smaller bottom bracket bearings so there will be more likelihood of replacing the BB due to wear/grit getting in.
    Size of chainrings will only matter if you already spend significant time in your very largest gear and think you are pedaling too fast.
    I can't weigh in on their relative flexibility, but I find that the Octalink needs a LOT more attention (read: re-torqueing) than the square tapered ones. Failure to do so has results in both BB and Crank damage.
    Caveats:
    - my experience with Octalink is limited to road components (105 and
    - I am a Clyde, and I love cranking up steep grades
    First bullet above should have noted "105 and Ultegra" components...
    I replaced my Octalink with a sqaure taper after replacing the Octalink 3 times in a year. This was on my 42 lb Santa Bruz Bullit that was used on lift access runs in Colorado. I have been very happy with my FSA BB on my roadbike that is an Octalink style.
    Hi.
    Reputation: jtmartino's Avatar
    Octalink is more expensive than square taper with not much benefit. There also seem to be many more used square taper BBs and cranksets than octalink on craigslist and ebay.
    If it were up to me, I'd stick with square taper.
    sorry..for emerging the old thread this thread has been burried for long time though.
    I don't know if it's only my suggestion or what.
    but I think octalink is better than the square tapper.
    I used to use the UN26 square tapper and after I upgraded it to Alivio octa, I can feel that I can go faster and get a light cadence with octa rather than before with square tapper.
    that is my opinion.
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    Get Shimano SLX, with the Hollowtech II bottom bracket. Octalink is not much an improvement...where Hollowtech is nearly light-years ahead. Money well spent....
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    psycho cyclo addict
    Reputation: edubfromktown's Avatar
    Octalink was more flexy than square taper for me. Shimano M952 cranks & Octalink BB were hitting the non drive side chainstay (at the peak of my right foot power stroke). Shimano BB-UN-73 with White Industries import Sugino ST cranks (off an old homegrown Schwinn) do not flex at all. You can still get this BB from Jenson- doesn't get much better than that one (other than Phil Wood or the older/discontinued BB-UN-72).
    Reputation: Sickmak90's Avatar
    May 2012
    I've had both and I'm not impressed with the octalink. I have to retorque it a lot, but it works I guess.
    Square taper gets a hard time because it's "old". It's perfectly fine for most people. It seems to me that quality of BB makes a difference, but I've used a VP square taper (not high-end) in two different bikes and it was great. I put an octalink on my wife's bike and that feels fine as well. I have a Shimano external BB on my main bike which feels a bit stiffer, which I prefer, but I wouldn't be depressed if I had to use square or octalink.
    It seems to me the differences in properly functioning and decent quality BBs is not significant enough for most people to really make a difference in their performance.
    I don't really notice much difference between square taper and any of the other systems since my bike frames are all on the flexy side. What I did notice was strength, back when I was younger and rode like a maniac I'd bend a square taper BB every so often from doing big drops to flat or landing a jump wrong. I never managed to bend an Octalink or ISIS BB, and I suspect I'll never bend the newer ones.
    I would go with the Sq.Tpr because of the cheap costs when your BB fails, and they are pretty much bomb proof, Never go with ISIS because its POS, I managed to kill an ISIS BB with less than 50 kilometers on it.
