Results 1 to 12 of 12
    Apr 2005
    crankset question
    Hi, I am looking at getting a new set of cranks and found a good deal on some hussefelts with
    a BB. I currently use an 8 speed drivetrain, can i still use these 9 speed cranks with all of my 8 speed stuff? Thanks, Kevin
    Mantis, Paramount, Campy
    Reputation: Shayne's Avatar
    Yes, they should work fine.
    Apr 2005
    Another question: now I am looking at XT cranks. Is this the tool i would need to install the octalink BB? Any reason i should get XT over hussefelt?
    Reputation: lebikerboy's Avatar
    Jan 2005
    XT cranks are stiffer, lighter, and the BB interface is better. The tool you need to install is shown below...
    Quote Originally Posted by Yeti342
    Apr 2005
    Thanks for the help, Kevin.
    Apr 2005
    So is this what i need?
    The devil is an angel too
    Mar 2005
    Maybe, that is the tool if you are getting "old style" Octalink, with the spindle not permanently attached to the arms. If you are getting the new style Ocatlink II -or whateva' they calls them- then you need the tool that lebikerboy shows you.
    Long story short, if the cranks don't come with a bottom bracket, you need the first tool you found, if they do, you need the second tool mmm'kay?
    Ah, XT vs.Hussefelt? dunno, XT lighter, Hussefelt stronger. XT more general use (use, not ABUSE) Hussefelt abuse friendly. Husefelt ISIS BB, no fun. If you do a lots of jumping and hucking, try looking into a Saint or RF Diabolous, otherwise XT should be fine.
    Apr 2005
    The cranks dont come with the BB i am buying that seperately both from nashbar. They say octalink not octalink 2 so i need the first tool right?
    Mar 2005
    Good job!
    Yes, you will need tool#1, and you are getting a pretty sweet deal. If you are not into really big jumping-freeriding stuff, those should work fine. You may want to buy a crank puller since you are at it. You don't need it to install the cranks, but you'll need it to remove them for servicing and stuff. And if you are a tool ho like most of us, you have to have it even if you only use it once
    Apr 2005
    Its going on abanshee scirocco set up for aggressive XC and trail riding, a few jumps but no huge hucks. I already have a crank puller and i am assuming i dont need a different one, or do i? Thanks for all the help, Kevin
    Mar 2005
    Cranks should be ok, if you are using splined cranks (ISIS or Shimano's) the puller will work. If you have a puller for square tapered it won't work.
    Reputation: wickerman1's Avatar
    Quote Originally Posted by FrozenK
    Totally!!
  1. General crankset question..
    By FoShizzle in forum Singlespeed
    Last Post: 03-20-2005, 11:24 PM
  2. Creaky crankset question
    By Andrewpalooza in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-25-2005, 06:33 PM
  3. shimano xtr 2003 crankset question
    By m4dj4ck in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-03-2004, 08:11 PM
  4. crankset question...
    By ryman in forum Titus
    Last Post: 09-02-2004, 10:41 AM
  5. 04 XT crankset install on NRS install question
    By dirt diggler in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-13-2004, 08:04 AM
