Thread: Crankset help!
    Apr 2013
    Crankset help!
    I went out today on my Specialized Hardrock and while hitting a climb, the chain came loose and grabbed the granny gear bending it nearly in half. After a little research, I found I've got a crappy SR Suntour XCT crankset with everything riveted on. So I'm stuck replacing the whole deal. I'd like to upgrade to something that is bolted together so I can avoid this in the future. I've got a 7 speed cassette and the new crankset also needs to be fairly sturdy because I'm a big boy. Something in the $100-200 range would be great but ill spend more if need be. I'd really appreciate some help with this.
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    Quote Originally Posted by burnout083 View Post
    just search online.. in the price range you're looking at just about anything will work. Just look for a 9 speed crank (7,8,9 speed cranks are all the same) probably actually look and the low-mid priced ones as most of the time the cheaper ones are heavier, but stronger.
    If you can find one, a Sram/Truvativ Stylo Is what I would recommend, but they are hard to find now. I'd suggest an external BB system (80% of cranks today are)
    Sram X7 or X9 or a Shimano SLX would be my 1st choices. I prefer the Sram's GXP mounting system...
    Not big on Race face As I don't like the drive side being the bolt on side.
    another option is contact Suntour,.. I hear their higher end products are getting MUCH better and I know in forks/shocks they have an upgrade program where they give a good bit off to get a new product if upgrading an existing Suntour unit. still end up with a Square taper I believe but then you'll be just pulling the arms off and using the new ones.. which will be lighter/stronger and interchangable rings.... worth a 5 min call
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
    Mar 2013
    I personally would go SLX 9 speed. Tried and true crank set that will outlast you. You can find them online fairly cheap and replace that BB. My guess is that if it is original that it is worn out and needs replacing anyways. With a new BB and Crank bike will prolly feel like brand new itself. The other thing with the SLX is that it is all bolt on so if you do manage to damage a ring you can easily replace or even change out rings for different sizing to suit your riding style or area.
    Mar 2011
    I just upgraded my crankset to a shimano SLX (9 speed)
    couldn't be happier, I got the 2 ring and bash guard model, worth taking a look into. It is the same price, I just never used the large ring when on dirt
  1. Differences in strength between XT 780 triple crankset and the 785 double crankset??
    By zoro in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-15-2013, 03:11 AM
  2. Tallboy with XT crankset to XTR crankset?
    By Rev. 14 in forum 29er Components
    Last Post: 04-15-2012, 06:11 PM
  3. Can I put the small ring (22) from an M542 Crankset onto a Deore XT M781 crankset?
    By bobonker in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-08-2012, 11:04 PM
  4. Crankset
    By Oz in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-15-2012, 06:50 AM
  5. Chainline difference in a 2x crankset vs a 3x crankset?
    By fire_strom in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-09-2011, 06:50 PM
