Results 1 to 6 of 6
    Crankset that fit my bike?
    Planning to buy a bike that has this bottom bracket and crankest:
    SRAM GXP bottom bracket spacers 68 to 73 BB
    Mod SRAM Truvativ Stylo crankset including bottom bracket
    (not sure what spacers 68 to 73 means)
    What cranksets I can use with that bottom bracket? I'm plannign to change the crankset because the included Stylo has small Q factor and my hips are wide so I like a little wider Q factor.
    I'm looking something on the cheap side. Shimano has a lot of cranks under 100 but there's only one GXP crankset that I found under 100 which is Firex Trekking 3.3 and that seem to have wider Q factor since the crank arms are not straight, but it's a bit pricey.
    Is it possible to change the bottom bracket to different model like Shimano maybe? Then I would have more options for proper crankset.
    Anyone?
    May 2013
    There is the Truvativ AKA 2.1 crankset with GXP bottom bracket included for very cheat at Merlin Cycles for about 70 euros : Truvativ AKA Chainset & Bottom Bracket | Chainsets - MTB | Merlin Cycles
    This one have a removable spider and it's a nice one. I bought one myself and installed it yesterday, it's great.
    As for the 68 vs 73 mm BB, some bike come with a 68mm wide bottom bracket body and others have 73 mm. The GXP include two 2.5mm spacers to be able to install on a 68mm. If you have a 73mm BB, you don't need spacers.
    Yes that's one option.
    Thanks for the information about 68 vs 73mm BB.
    Could I replace the GXP BB with Shimano Deore or SLX rankset compitable BB? I just want to know what the options are before ordering the bike.
    Reputation: mitzikatzi's Avatar
    A Sram crank set needs a GXP type bottom bracket.
    A Shimano crank set needs a Shimano type bottom bracket.
    Both will fit your frame with the correct spacers.
    Duct tape iz like teh Force. It has a Lite side and a Dark side and it holdz the Universe together.
  1. X9 Fat Bike Crankset
    By GTR2ebike in forum Fat bikes
    Last Post: 03-28-2013, 07:27 AM
  2. WTB: Fat Bike crankset
    By deuxdiesel in forum Fat bikes
    Last Post: 11-13-2012, 04:28 AM
  3. I need a black 48/38/28t crankset for my bike
    By TX-Shooter in forum General Discussion
    Last Post: 10-02-2011, 12:08 PM
  4. Whats the best Mtn bike Crankset?? Under 200.00
    By neoison in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-29-2011, 06:54 PM
  5. crankset suggestions for my bike.
    By mike29erss in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-23-2011, 12:47 PM
