not ANY bike, but it will certainly fit yours. A couple of things you will have to do though. You'll need a new chain, the stock big ring on your 4300 is a 42 tooth, the big ring on the LX is a 44T. The two extra teeth make for a larger diameter ring, you'll need a couple of extra links to make up for it and allow full use of the cassette without buggering the rear derailleur. Granted cross chaining is a no-no, but it does happen. Also you'll likely need to adjust the front derailleur upward a bit so that it clears the teeth on the LX big ring. Since the front derailleur is a top pull, adjusting upward will put slack in the cable. So you'll have to loosen up the anchor bolt and remove the slack. The LX crank may also have a bit different chainline than your stock crank so limit screws may have to be adjusted as well. It'll work, you'll just have to make some adjustments.
Good Dirt
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
