Results 1 to 5 of 5
    Crankset with 46/48 teeth chainring
    Any suggestion if I don't prefer a custom-built one?
    President, CEO of Earth
    Reputation: TobyNobody's Avatar
    46 and 48??
    Are you looking for a crank with both 46 and 48 t chainrings? Because in all my readings of national wholesale distributors I have never seen a crank with that combination offered as a regular item. Some cranks come with a no chainring option (like Raceface) and you could get any size of rings to put on those.
    This type of thing used to be more common (called half-step gearing) because it shifted a lot better with the front derailleurs of the day then the 'full step' gearing. However, this was really sort of passé by the time I got my first job in a shop in the late '80s.
    Aside from that, you're probably gonna have to buy a crank with a 48 big ring and buy a 46 (or vise versa) to make your desired combination.
    Quote Originally Posted by TobyNobody
    I am sorry to make the confusion.
    What I mean is that is there any good crankset with the largest chainring being 46 or 48 teeth?
    Will the custom-built crankset be more expensive and shift better than the factor-made crankset?
    Airbomb has Deore/LX in 26/36/48
    Besides using a 110/74 crank (Sugino XD500), Airbomb shows that they have the Deore and Deore LX four arm cranks with a 48. However, Shimano specs their front derailleur to handle only 22 teeth difference. You might be able to get away with more than 22t but you should be aware of it.
    glenk
    all hail der Fuhrer Bush
    there are
    what you seek is a crankset with the vererable 110/74mm "standard" bolt circle diameter, vs today's various "compact" versions.
    They're still around. Middleburn outa england makes one that's a lot like the original first-generation xtr of a decade ago. sugino still makes one, or some. TA also does.
    www.rivendellbicycles.com carries some for sure, Grant the owner is a big proponent of the standard bolt circle diameter. he may not have the best prices, though.
    might be some old ritchey logic standards on ebay. they're cold-forged sugino. or if you prefer cnc machined, cook bros, etc etc. they were the standard for like 2 decades so there should still be plenty floating around.
    ah, cranksets don't shift, custom or otherwise. it's the chainrings you put on the cranksets that would account for any differences in shifting quality.
    46 or 48t big rings were pretty much standard for standard cranks. smallest middle ring = 34t.
    smallest granny ring you can actually find =24t, though I have heard rumors of 23t grannies out there somewhere.
  1. Trying to install crankset.....left crank arm rubbing BB
    By bayarearider in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-12-2004, 11:16 AM
  2. help with e13 (chainring size)
    By oli_f in forum Downhill - Freeride
    Last Post: 07-06-2004, 05:53 PM
  3. Snapped a chainring bolt last night
    By Birdman in forum Singlespeed
    Last Post: 07-01-2004, 11:15 AM
  4. Is your front chainring Ovalized?
    By fc in forum Singlespeed
    Last Post: 06-11-2004, 01:43 PM
  5. 8-speed chainring teeth numbers
    By jmoney in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-26-2004, 07:21 AM
